RE: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’
- From: Chris Brinkley <Chris.Brinkley AT sslmda.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’
- Date: Tue, 23 Aug 2016 18:48:05 +0000
- Accept-language: en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Chris.Brinkley AT sslmda.com; spf=None smtp.mailfrom=Chris.Brinkley AT sslmda.com; spf=None smtp.helo=postmaster AT mx0a-00142601.pphosted.com
- Ironport-phdr: 9a23:cPOjwBTTS/2IjMvYPXRJnBjbzNpsv+yvbD5Q0YIujvd0So/mwa64bBGN2/xhgRfzUJnB7Loc0qyN4vmmAjBLuMzQ+DBaKdoXBkdD0Z1X1yUbQ+e9QXXhK/DrayFoVO9jb3RCu0+BDE5OBczlbEfTqHDhpRQbGxH4KBYnbr+tQt2asc272qiI9oHJZE0Q3XzmMOo0d0n99F+A/olO2M05e/53kkOI6lJzOM1ujVtyIlySmxuuruyRx7VEtxpqhvQ66sRbWr/7dalrBZZRDTAhLnxnrJaz7UqLHkOz4S5WWWIP1xFMHgLt7RfgX563vDGw/r523zDfNsnrR5g1Xy6j5uFlUkm7pj0AMmsS8HvWkYRalqNdoxastlQr6I7OYZrTHuB/eKDZcMIyXnFFW8pYESdGB9XvPMM0E+MdMLMA/MHGrFwUoE7mCA==
Using make with the new unmodified source files seems to have resolved the issue. Thanks again to all!
Chris
Benjamin,
FYI, I tried restoring the new unmodified source files into the sf directory, overwriting the older completed versions I had put in there. At least using the Compile option in ProofGeneral, I still got the same error. I will try taking your advice, though, to move forward using the unmodified new source files, as I try to implement the other suggestions. Thanks for the heads-up.
Chris
coq-club-request AT inria.fr [mailto:coq-club-request AT inria.fr]
On Behalf Of Benjamin C. Pierce
Hi Chris,
The easiest solution is just to set aside the old files and switch over to the new SF sources for all the files. All the later files will compile with the distributed (solution-less) version of the earlier ones, and you’ll avoid problems with other incompatibilities between the SF versions — we made a lot of changes in the 4.0 release.
Best,
- Benjamin
This message (including any attachments) may contain confidential information intended for a specific individual and purpose. If you are not the intended recipient, you should delete this message and any attachments. |
- [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Chris Brinkley, 08/23/2016
- RE: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Soegtrop, Michael, 08/23/2016
- Re: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Randy Pollack, 08/23/2016
- Re: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Benjamin C. Pierce, 08/23/2016
- RE: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Chris Brinkley, 08/23/2016
- Re: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Hengchu Zhang, 08/23/2016
- RE: [Coq-Club] The file ident.vo contains library dirpath and not library dirpath’, Chris Brinkley, 08/24/2016
