- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] non-automatic type class resolution
- Date: Thu, 1 Sep 2016 19:38:17 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f175.google.com
- Ironport-phdr: 9a23:1PxlGRI4w0AHTwB3uNmcpTZWNBhigK39O0sv0rFitYgXLfjxwZ3uMQTl6Ol3ixeRBMOAuqsC1rCd6PqoGTRZp83e4DZaKN0EfiRGoPtVtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdaymUrLV2s+wzqW5/4DZSwROnju0J71ofzusqgCElM4QiJdiI6B57hbIvHZOZ6wCx2RuJFGemxvxzsi19Z9ntS9XvqRypIZ7TazmcvFgHvRjBzM8PjVt6Q==
On 09/01/2016 07:19 PM, Vadim Zaliva wrote:
Sometimes I wish I can avoid automatic typeclass resolution and make it
generate sub-goals for all unresolved type class instances. Then I can
proceed and prove them manually, instead of using Hints, etc. Something
like 'unshelve':
The following example:
Class A (n:nat) : Prop.
Definition f (n:nat) `{A n} := n.
Definition g (n:nat) := n.
Lemma Foo: forall x, f (g x) = x.
In absence of:
Instance A_g: forall x, A (g x).
gives me:
Error:
Unable to satisfy the following constraints:
In environment:
x : nat
?H : "A (g x)"
And I could not proceed with the proof. Why couldn't it just generate a
sub-goal for A (g x) ?
Is there is a way to achieve this behavior in current version?
Is this sufficient?:
Definition f (n:nat)`{A n} := n.
Lemma Foo: exists w, forall x, @f (g x) (w x) = x.
unshelve eexists.
-- Jonathan
- [Coq-Club] non-automatic type class resolution, Vadim Zaliva, 09/02/2016
- Re: [Coq-Club] non-automatic type class resolution, Jonathan Leivent, 09/02/2016
- Re: [Coq-Club] non-automatic type class resolution, Vadim Zaliva, 09/02/2016
