- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] non-automatic type class resolution
- Date: Thu, 1 Sep 2016 21:36:40 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f176.google.com
- Ironport-phdr: 9a23:I+3O1B3bmpztKcD9smDT+DRfVm0co7zxezQtwd8ZsegTLfad9pjvdHbS+e9qxAeQG96KsrQZ0aGL6+igATVGusfZ9ihaMdRlbFwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oMyKJVgSz2flKfMqdVPt/F2X7pFXyaJZaY8JgiPTpXVJf+kEjUhJHnm02yjG28Gr4ZR4+D5Rsf9yv+RJUKH9YrhqBecAVGduYCgJ45jgsgCGRg+S7FMdVH8Xm1xGGVvr9hb/C7X2tCLmtuN7kA2XPNP7S6x8DTal6aZoRRvlhQ8IMjc49Cfcjckm3/ETmw6ouxEqm92cW4qSLvcrJq4=
On 09/01/2016 07:38 PM, Jonathan Leivent wrote:
On 09/01/2016 07:19 PM, Vadim Zaliva wrote:
Sometimes I wish I can avoid automatic typeclass resolution and make it
generate sub-goals for all unresolved type class instances. Then I can
proceed and prove them manually, instead of using Hints, etc. Something
like 'unshelve':
The following example:
Class A (n:nat) : Prop.
Definition f (n:nat) `{A n} := n.
Definition g (n:nat) := n.
Lemma Foo: forall x, f (g x) = x.
In absence of:
Instance A_g: forall x, A (g x).
gives me:
Error:
Unable to satisfy the following constraints:
In environment:
x : nat
?H : "A (g x)"
And I could not proceed with the proof. Why couldn't it just generate a
sub-goal for A (g x) ?
Is there is a way to achieve this behavior in current version?
Is this sufficient?:
Definition f (n:nat)`{A n} := n.
Lemma Foo: exists w, forall x, @f (g x) (w x) = x.
unshelve eexists.
This might be better:
Lemma Foo: forall x, exists w, @f (g x) w = x.
intro x.
unshelve eexists.
I think using an evar - either one created by exists or by the evar tactic (not refine) - are the only ways to create a subgoal of a class type that Coq doesn't immediately try to resolve. To use refine to do this, I think you have to create the hole with some other type that you can reduce to the desired class.
-- Jonathan
- [Coq-Club] non-automatic type class resolution, Vadim Zaliva, 09/02/2016
- Re: [Coq-Club] non-automatic type class resolution, Jonathan Leivent, 09/02/2016
- Re: [Coq-Club] non-automatic type class resolution, Vadim Zaliva, 09/02/2016
