coq-club - Re: [Coq-Club] help with automating derived UIP_refl proofs
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] help with automating derived UIP_refl proofs
  • Date: Thu, 08 Sep 2016 10:43:02 +0200
  • Organization: LORIA
On 09/02/2016 01:08 AM, Jason Gross wrote:
> You should prove that UIP is preserved by sigma types. Then you can
> turn dependent fields into a single non-dependent one, and use UIP on
that.
A proof that UIP is preserved by sigma types. Remark that eq_rect
is useful here to implement equality between terms of "isomorphic"
dependent types (ie P a <~> P b when a = b).
Dominique
Definition uip (X : Type) := forall (x : X) (H : x = x), H = eq_refl.
Section sigma_type.
Variables (X : Type) (P : X -> Type).
Let sigma_eq (x y : X) (H : x = y) (a : P x) (b : P y) : eq_rect _ P a
_ H = b -> existT _ x a = existT _ y b.
Proof.
destruct H; simpl.
intros []; reflexivity.
Defined.
Let eq_sigma_inv (x : sigT P) : forall y, x = y -> Prop :=
match x with
| existT u a => fun y =>
match y with
| existT v b => fun H => exists (e1 : u = v) (e2 : eq_rect _ P a
_ e1 = b), H = sigma_eq _ _ e1 _ _ e2
end
end.
Let eq_inv x y H : @eq_sigma_inv x y H.
Proof.
subst y.
destruct x as [ x t ]; simpl.
exists eq_refl; simpl.
exists eq_refl; reflexivity.
Qed.
Hypothesis uip_X : uip X.
Hypothesis uip_P : forall x, uip (P x).
Theorem uip_sigma_type : uip (sigT P).
Proof.
intros [ x t ] H.
generalize (eq_inv _ _ H); simpl.
intros (e1 & H1).
rewrite (uip_X _ e1) in H1; simpl in H1.
destruct H1 as (e2 & H2).
rewrite (uip_P _ _ e2) in H2; assumption.
Qed.
End sigma_type.
Check uip_sigma_type.
