- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] any down side to making all definitions Instances?
- Date: Thu, 08 Sep 2016 11:38:51 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=theo.zimmi AT gmail.com; spf=Pass smtp.mailfrom=theo.zimmi AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f53.google.com
- Ironport-phdr: 9a23:Box2XBOziLIi+JYY8WMl6mtUPXoX/o7sNwtQ0KIMzox0K/v/rarrMEGX3/hxlliBBdydsKMdzbSM+Py7ESxYuNDa7yBEKMQNHzY+yuwo3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9ScbuiJG80Pn38JnOaS1JgiC8aPV8NkaYtwLU4/UWAIxVGKc0zxbTp3JOfawC2WNlIhSBnhP55++/+Zdi92JbvPd3pJ0IarnzY6ltFe8QNz8hKW1gvMA=
You might be interested by Pierre-Évariste's, still experimental, "cortouche" plugin:
https://github.com/pedagand/cortouche
So far it only looks for witnesses in the proof environment though, so it is not exactly the same as what you are proposing.https://github.com/pedagand/cortouche
Le mer. 7 sept. 2016 à 19:39, Jonathan Leivent <jonikelee AT gmail.com> a écrit :
I've been experimenting with ways to refer to things by their type
instead of by name. One that seems obvious is using a very generic
typeclass for all definitions that aren't already Instances of some
other typeclass:
Class Witness (signature : Type) := witness : signature.
Then, for any Definition/Lemma of the form : "Lemma Foo : <quantifers>
-> T", I would instead define "Instance Foo : <quantifiers> -> Witness
T". The proof just needs an extra "unfold Witness" at the beginning.
The definitions are still usable by name. But, because they are now
instances, I can also look them up by type, as with "pose proof (witness
: T)". A Generalize_Witness instance allows a single other instance to
be found by any of its possible generalizations:
Instance Generalize_Witness{A : Type}{B : A -> Type}(H : forall a,
Witness (B a)) : Witness (forall a, B a).
Proof.
red. apply H.
Defined.
The question is - is there a down side to doing this for all
definitions? Would I be slowing down instance resolution on non-Witness
classes as a result? Also, might there be some way a definition can be
used such that an Instance in its place won't work as well?
-- Jonathan
- [Coq-Club] any down side to making all definitions Instances?, Jonathan Leivent, 09/07/2016
- Re: [Coq-Club] any down side to making all definitions Instances?, Théo Zimmermann, 09/08/2016
- Re: [Coq-Club] any down side to making all definitions Instances?, Jonathan Leivent, 09/08/2016
