- From: Gaetan Gilbert <gaetan.gilbert AT ens-lyon.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Some questions about tactics in Coq
- Date: Mon, 12 Sep 2016 14:21:51 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT ens-lyon.fr; spf=Pass smtp.mailfrom=gaetan.gilbert AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
- Ironport-phdr: 9a23:yZldpRJ65NB//R2hJdmcpTZWNBhigK39O0sv0rFitYgULP7xwZ3uMQTl6Ol3ixeRBMOAuqsC1bqd7/GoGTRZp83Q6DZaKN0EfiRGoP1epxYnDs+BBB+zB9/RRAt+Iv5/UkR49WqwK0lfFZW2TVTTpnqv8WxaQU2nZkJLL+j4UrTfk96wn7jrvcaCOkMW1HHhMPsydEzw9lSJ8JFOwMNLEeUY8lPxuHxGeuBblytDBGm4uFLC3Pq254Np6C9KuvgspIZqWKT+eLkkH/QDVGx1ezN92Mq+vh7aCACL+3E0U2MMkxMODRKWwgv9W8Leuybmv+w19yieN8DsUfhgVj2v865tDhDpjC0KLSIR/WfMz8hhi6Qdrgj39E83+JLdfIzAbKk2RajaZ95PHWc=
For 1) and 3) I think you would use Tactic Notation https://coq.inria.fr/distrib/current/refman/Reference-Manual014.html#hevea_command230
eg
Tactic Notation "tactic_example" whatever(H) "in" hyp(H') := code of tactic_example_in.
According to the manual it can be used to get argument lists but I don't know how that part works.
Gaëtan Gilbert
On 12/09/2016 14:00, Sebastian Böhne wrote:
Dear Coq-community!
I've accumulated some questions about tactics in Coq. It would be very nice if you could help me with some of these. (I'm using CoqIDE (8.4pl3)):
1) Tactics like simpl can be used in hypotheses as well by adding 'in Hyp' at the end. Is it possible to define my own tactics in that style, too? So far in such cases I defined tactics like tactic_example H and a second one called tactic_example_in H H' for use in the hypotheses, but I would prefer to be able to write tactic_example H in H' in the latter case.
2) When I want to unfold a notation I can first locate it ('locate "operator-sign"') and then do an unfold with the real non-abbreviated name. However, I would appreciate a direct way. Is there a tactic to do so?
3) Is it possible to define tactics like intros which get a list as input? Up to now I made different tactics like my_tactic_n for n up to 5 or so for the different numbers of arguments, but this is not really satisfying.
4) I would like to build an induction-tactic which behaves a little bit different than the original one: It should only match with the current goal and should not be the induction of one of the hypotheses. So far I know how to do it. Another thing is, however, that when applied the original induction tactic makes some intros automatically. For instance when using induction for nat, one subgoal is P(0) (which is ok), while the other is P(Suc n) where n : nat and P(n) are already assumed. I would prefer if it would be simply ∀ n : nat, P n → P (Suc n) as goal instead.
It is no problem to create such a tactic for special cases (like nat), but I would like a tactic as general as the orginal one. The problem seems to me to be that I somehow had to use A_ind for the different inductive types A. Yet ind A or something like that does not work since ind is not a total function and I don't know how to refer to A_ind otherwise.
Another attempt would be to use induction and to regeneralise the hypotheses, but then I need the names and the number of the hypotheses for reconstruction. This in turn seems to me to amount to the same problem of having to know A_ind.
Thank you very much and best regards
Sebastian Böhne
- [Coq-Club] Some questions about tactics in Coq, Sebastian Böhne, 09/12/2016
- Re: [Coq-Club] Some questions about tactics in Coq, Gaetan Gilbert, 09/12/2016
- Re: [Coq-Club] Some questions about tactics in Coq, Clément Pit--Claudel, 09/12/2016
- <Possible follow-up(s)>
- Re: [Coq-Club] Some questions about tactics in Coq, Sebastian Böhne, 09/18/2016
- Re: [Coq-Club] Some questions about tactics in Coq, Gaetan Gilbert, 09/18/2016
