coq-club - Re: [Coq-Club] Some questions about tactics in Coq
  • From: Gaetan Gilbert <gaetan.gilbert AT ens-lyon.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Some questions about tactics in Coq
  • Date: Sun, 18 Sep 2016 13:43:01 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT ens-lyon.fr; spf=Pass smtp.mailfrom=gaetan.gilbert AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
  • Ironport-phdr: 9a23:xtNUARXtZjy3KpBdSFDVzVOFznPV8LGtZVwlr6E/grcLSJyIuqrYZROOt8tkgFKBZ4jH8fUM07OQ6PG5HzxZqsrZ+DBaKdoXCE9D0Z1X1yUbQ+e7SmTDZMbwaCI7GMkQHHRExFqcdXZvJcDlelfJqWez5zNBUj/2NA5yO/inUtWK15f/hKiO/MjYZBwNjz6ga5tzKg+3pEPfrJo4m4xnf4k4xwfApDNneuBcyHl0bQaclhvg78H2859n+SlKp9os8dUFVbT9eeI2V+oLX3wdL2kp6Ziz5lH4RgyV6y5EXw==
4) Isn't that just [simple induction]?
eg
Variable P : nat -> Prop.
Goal forall n, P n.
simple induction 0.
- (* n : nat |- P 0 *) admit.
- (* n : nat |- forall n0 : nat, P n0 -> P (S n0) *) admit.
Abort.
Gaëtan Gilbert
On 18/09/2016 13:32, Sebastian Böhne wrote:
Thank you Gaëtan Gilbert and Clément Pit--Claudel for your answers! They already helped a lot!
1) The suggestion to use tactic notations for writing tactic_example H in H' instead of tactic_example_in H H' indeed works. Yet, there were to thinks to consider:
a) I first tried:
Tactic Notation "my_tactic" hyp(H) "in" hyp(H') := my_tactic_in H H'.
This was problematic since I sometimes want to use the tactic with a lemma for H. This is why I had to use
Tactic Notation "my_tactic" constr(H) "in" hyp(H') := my_tactic_in H H' instead.
b) A second problem was that with this notation I was not allowed to use my tactic my_tactic anymore. I solved the problem by renaming the original my_tactic in my_tactic_not_in and making a second tactic notation, namely
Tactic Notation "my_tactic" constr(H) := my_tactic_not_in H.
This does not seem to clash with the former tactic notation.
2) unfold "sign" does indeed work. For some reasons I thought I had tried this, but I was wrong.
3) Tim Richter, a colleague of mine, helped me with the third point. We were partially successful: We wanted a tactic
my_tactic H X1 ... Xn (where n = 0 is possible).
Instead we were able to make a tactic, called
my_tactic' H X1 ... Xn False
instead, which behaved like my_tactic H X1 ... Xn should (False could be replaced by something else. It is only a dummy). However,
my_tactic H L := my_tactic' H L False
does not work, except with exactly one argument. We tried
Tactic Notation "my_tactic" constr(H) ident_list(L) := my_tactic' H X1 ... Xn False,
but this does not work neither: Coq exspects a "." after my_tactic H, so for instance my_tactic H X1 X2 X3 does not work. Furthermore my_tactic H produces another error, which might be special to our tactic:
"Must evaluate to a closed term
offending expression:
t
this is a VList."
Does somebody have an idea how to go from my_tactic' to my_tactic?
4) My fourth question was not answered yet; perhaps due to the other questions. So I repeat it.
I would like to build an induction-tactic which behaves a little bit different than the original one: It should only match with the current goal and should not be the induction of one of the hypotheses. So far I know how to do it. Another thing is, however, that when applied the original induction tactic makes some intros automatically. For instance when using induction for nat, one subgoal is P(0) (which is ok), while the other is P(Suc n) where n : nat and P(n) are already assumed. I would prefer if it would be simply ∀ n : nat, P n → P (Suc n) as goal instead.
It is no problem to create such a tactic for special cases (like nat), but I would like a tactic as general as the orginal one. The problem seems to me to be that I somehow had to use ind_A for the different inductive types A. Yet ind A or something like that does not work since ind is not a total function and I don't know how to refer to it otherwise.
Another attempt would be to use induction and to regeneralise the hypotheses, but then I need the names and the number of the hypotheses for reconstruction. This in turn seems to me to amount to the same problem of having to know ind_A.
Thank you and best regards
Sebastian Böhne
