- To: Ilmārs Cīrulis <ilmars.cirulis AT gmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] A question about notation.
- Date: Tue, 13 Sep 2016 01:41:00 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=ilmars.cirulis AT gmail.com; spf=Pass smtp.mailfrom=ilmars.cirulis AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f173.google.com
- Ironport-phdr: 9a23:NSQ9lRGf6GQR+FAknJg/BZ1GYnF86YWxBRYc798ds5kLTJ75o86wAkXT6L1XgUPTWs2DsrQf2rOQ7fGrADBIoc7Y9itdINoUD15NoP5VtjJjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScaBx/iwgsG2/jbJeE1jhSCgZbJpZEG3qQDYrNJQiop4N6Iw0TPGp3JJf6JdwmY+YRrZlBHlo8y04ZRL8iJKuvtn+dQKGfHxeL19RrhFBhwnNXo07Yvlr0+QYxGI4y49VmC9iAEAKAnf8RX7Rd+lsy//v/BmniKbJ9DyTKscVjGr7qMtQxjt3nRUfwUl+X3a35QjxJlQpwis8kRy
Thank you!
Maybe it's useful someone else who tinkers with naive set theory.
As I have Coq on Windows for now, I will simply wait for new version.
My current workaround is such:
Require Import Utf8 List.
Set Implicit Arguments.
Fixpoint list_as_pred T (L: list T): T → Prop :=
λ a, match L with
| nil => False
| x :: nil => a = x
| x :: t => a = x ∨ list_as_pred t a
end.
Notation "{ x , .. , z }" := (list_as_pred (cons x .. (cons z nil) .. )).
Definition empty_set {T} := λ (x: T), False.
Notation "{ }" := empty_set.
Definition X := {1}. Print X.
Definition Y := {1, 2}. Print Y.
Definition Z: nat → Prop := {}. Print Z.
On Mon, Sep 12, 2016 at 6:30 PM, Hugo Herbelin <Hugo.Herbelin AT inria.fr> wrote:
Hi,
You actually made nothing wrong. This is a bug, with a short fix at [1]
if ever you'd like to recompile Coq with it.
I don't see an immediate workaround, except binding also "a" in the
recursive notation, or expanding the recursive notation into a
collection of finite instances of it.
Best,
Hugo Herbelin
[1] https://github.com/coq/coq/commit/90e5945e1666540bc18e7a9b831d136041f4e487
On Mon, Sep 12, 2016 at 05:13:55PM +0300, Ilmārs Cīrulis wrote:
> Hello,
> I made a notation and tested it. It was parsed correctly, but it wasn't
> display.
> Where is my mistake?
> Notation "{ x , y , .. , v }" := (fun a => (or .. (or (a = x) (a = y)) ..
> (a = v))): set_scope.
> Open Scope set_scope.
> Check ({1, 2}).
> The "check" command displays
> fun a : nat => a = 1 \/ a = 2
> : nat -> Prop
> while I would like to see something like this:
> {1, 2}: nat -> Prop
> Thank you!
- [Coq-Club] A question about notation., Ilmārs Cīrulis, 09/12/2016
- Re: [Coq-Club] A question about notation., Hugo Herbelin, 09/12/2016
- Re: [Coq-Club] A question about notation., Ilmārs Cīrulis, 09/13/2016
