- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Is eauto behavior desirable?
- Date: Thu, 15 Sep 2016 13:51:54 +0000
- Accept-language: de-DE, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=michael.soegtrop AT intel.com; spf=Pass smtp.mailfrom=michael.soegtrop AT intel.com; spf=None smtp.helo=postmaster AT mga02.intel.com
- Ironport-phdr: 9a23:AOInTx9zwZhwmP9uRHKM819IXTAuvvDOBiVQ1KB92+McTK2v8tzYMVDF4r011RmSDNydtK8P1bee8/i5HzdRudDZ6DFKWacPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvjotuMPk4W2XL9Oeo0d0Tu612J94E/ushLEu4J0BzHo39FKax95FhDAhatpSv6/dq655V58i5d6LoL/s9EVrjmLexjFeQLRGduD2dgrsbsrFzISRaFznoaSGQf1BRSSUCR5xbjG5z1ryHSt+xn2SDcM9egHp4uXjH3pZxsRRD0kiAfc3Yc8WrXg8F0xuoPpROqpxVyx8jPZ4yaKOB5Zovce88XQSxKWcMHBH8JOZ+1c4ZaV7lJBu1ftYSo/1Y=
Dear Coq Users,
as far as I can tell (it is not documented) eauto will execute any hint first, which solves the goal, regardless of priority in the database. This has the undesirable effect that eauto first checks all hints if they would solve the goal, even expensive ones. I tend to give priorities to extern hints such that expensive tactics are tried last, but this has no effect, if all tactics are tried before any tactic is executed.
I wonder how other uses see this. Do you think it is a great feature of eauto or not?
Best regards,
Michael Intel Deutschland GmbH |
- [Coq-Club] Is eauto behavior desirable?, Soegtrop, Michael, 09/15/2016
- Re: [Coq-Club] Is eauto behavior desirable?, Jonathan Leivent, 09/15/2016
- RE: [Coq-Club] Is eauto behavior desirable?, Soegtrop, Michael, 09/15/2016
- Re: [Coq-Club] Is eauto behavior desirable?, Matthieu Sozeau, 09/15/2016
- Re: [Coq-Club] Is eauto behavior desirable?, Jonathan Leivent, 09/19/2016
- RE: [Coq-Club] Is eauto behavior desirable?, Soegtrop, Michael, 09/20/2016
- RE: [Coq-Club] Is eauto behavior desirable?, Soegtrop, Michael, 09/16/2016
