coq-club - Re: [Coq-Club] Is eauto behavior desirable?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Is eauto behavior desirable?
  • Date: Thu, 15 Sep 2016 10:34:34 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f176.google.com
  • Ironport-phdr: 9a23:cJl+chwsgC40lufXCy+O+j09IxM/srCxBDY+r6Qd0u0SIJqq85mqBkHD//Il1AaPBtSCra0ZwLWK++C4ACpbvsbH6ChDOLV3FDY7yuwu1zQ6B8CEDUCpZNXLVAcdWPp4aVl+4nugOlJUEsutL3fbo3m18CJAUk6nbVk9dazJHdvZiN3y3OSv8bXSZR9JjXyze+BcNhKz+CfWsMAKgYJkYoI8ywXEpGcAL+ZRw2JrKFaekj7z486x+Nho9CEG6KFpzNJJTaivJ/dwdrdfFjlza20=
On 09/15/2016 09:51 AM, Soegtrop, Michael wrote:
Dear Coq Users,
as far as I can tell (it is not documented) eauto will execute any hint
first, which solves the goal, regardless of priority in the database. This
has the undesirable effect that eauto first checks all hints if they would
solve the goal, even expensive ones. I tend to give priorities to extern
hints such that expensive tactics are tried last, but this has no effect, if
all tactics are tried before any tactic is executed.
I wonder how other uses see this. Do you think it is a great feature of eauto
or not?
It wasn't until recently in 8.5 that eauto took the hint costs into consideration at all - it was previously trying hints in most-recent-first order regardless of cost. Yet few noticed.
-- Jonathan
