- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] are there specialists in linear algebra in the room?
- Date: Mon, 26 Sep 2016 12:04:13 +0200
On 09/26/2016 11:30 AM, Daniel de Rauglaudre wrote:
Question: I was even not able to prove it with pen and paper!
How did nsatz do it? Is it possible to see its proof, except
by typing "Show Proof"?
nsatz just implements the test for ideal membership using grobner basis.
Given polynomials P1.. Pn and Q, it checks if Q is in the ideal generated by P1 .. Pn, ie if Q can be written as Q = \sum_i Pi * Ri for some arbitrary polynomials Ri.
This solves exactly your problem that is P1= 0 -> ... -> Pn= 0 -> Q = 0.
The problem is decided by building a "canonical" base for the ideal (P1,..Pn) using a completion à la Knuth-Bendix.
What you have when you do Show Proof is mainly the Ri. Of course this is a bit obfuscated by the reification process.
Anyway this output is usually not for human consumption, nsatz does not try to get the "smallest" certificate....
Hope this helps
Laurent
- [Coq-Club] are there specialists in linear algebra in the room?, Daniel de Rauglaudre, 09/25/2016
- Re: [Coq-Club] are there specialists in linear algebra in the room?, Chris Dams, 09/25/2016
- Re: [Coq-Club] are there specialists in linear algebra in the room?, Laurent Thery, 09/25/2016
- Re: [Coq-Club] are there specialists in linear algebra in the room?, Daniel de Rauglaudre, 09/26/2016
- Re: [Coq-Club] are there specialists in linear algebra in the room?, Laurent Thery, 09/26/2016
