- To: coq-club AT inria.fr
- Subject: [Coq-Club] questions about using search command in coqtop ideslave
- Date: Wed, 5 Oct 2016 09:49:07 +0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=zjhsdtc AT gmail.com; spf=Pass smtp.mailfrom=zjhsdtc AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f53.google.com
- Ironport-phdr: 9a23:sG8HeRb2xpTQWCuL9oafmuH/LSx+4OfEezUN459isYplN5qZpc64bnLW6fgltlLVR4KTs6sC0LuM9fqwEjFeqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ3p7xjbD5psObSj4LrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVHSODxe7kyZb1eFjUvdW4vt+PxshyWXwmP/XcAWS1CgBhIGATZ5zn1W57wtm3xse8ri3rSBtH/Ub1hAWfq1KxsUhK90Co=
Hi all,
There is something that has confused me for quite a while. if we use coqtop -ideslave --help-XML-protocol
, it will produce a list of commands available in the ideslave
, e.g. the Goal
command, so we can simply send <call val="Goal"><unit/></call>
to ideslave, i can easily play around with these commands except the Search
one.
According to the brief documentation, it seems have to send a list of search constraint and boolean value pairs inside <call val="Search">...</call>
, but after trying and failing for many times, i still can not find a way to construct a qualified xml message to stand for a search command.
So is there any examples to use Search
command in ideslave or anyone have an idea how to use it?
Thank you,
- [Coq-Club] questions about using search command in coqtop ideslave, zjhsdtc, 10/05/2016
- Re: [Coq-Club] questions about using search command in coqtop ideslave, CJ Bell, 10/05/2016
- Re: [Coq-Club] questions about using search command in coqtop ideslave, zjhsdtc, 10/05/2016
- Re: [Coq-Club] questions about using search command in coqtop ideslave, James Smith, 10/05/2016
- Re: [Coq-Club] questions about using search command in coqtop ideslave, James Smith, 10/06/2016
