coq-club - Re: [Coq-Club] questions about using search command in coqtop ideslave
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] questions about using search command in coqtop ideslave
  • Date: Tue, 4 Oct 2016 23:53:10 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=siegebell AT gmail.com; spf=Pass smtp.mailfrom=siegebell AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f44.google.com
The code for encoding and decoding this call is here:
1. the type of the Search call is a list of pairs, the first being a constraint and the second a bool: https://github.com/coq/coq/blob/trunk/ide/xmlprotocol.ml#L464
2. the constraint type: https://github.com/coq/coq/blob/trunk/ide/xmlprotocol.ml#L25
3. the return type is a list of pairs of Coq objects and strings: https://github.com/coq/coq/blob/trunk/ide/xmlprotocol.ml#L488
Example search for regex "nat_rect.+":
<call val="Search"><list><pair><search_cst val="name_pattern"><string>nat_rect.+</string></search_cst><bool val="true"/></pair></list></call
Returns:
<value val="good"><list><coq_object><list><string>Coq</string><string>Init</string><string>Peano</string></list><list><string>nat_rect_plus</string></list><string>forall&nbsp;(n&nbsp;m&nbsp;:&nbsp;nat)&nbsp;(A&nbsp;:&nbsp;Type)&nbsp;(f&nbsp;:&nbsp;A&nbsp;-&gt;&nbsp;A)&nbsp;(x&nbsp;:&nbsp;A),
nat_rect&nbsp;(fun&nbsp;_&nbsp;:&nbsp;nat&nbsp;=&gt;&nbsp;A)&nbsp;x&nbsp;(fun&nbsp;_&nbsp;:&nbsp;nat&nbsp;=&gt;&nbsp;f)&nbsp;(n&nbsp;+&nbsp;m)&nbsp;=
&nbsp;&nbsp;(nat_rect&nbsp;(fun&nbsp;_&nbsp;:&nbsp;nat&nbsp;=&gt;&nbsp;A)&nbsp;x&nbsp;(fun&nbsp;_&nbsp;:&nbsp;nat&nbsp;=&gt;&nbsp;f)&nbsp;m)&nbsp;
&nbsp;&nbsp;(fun&nbsp;_&nbsp;:&nbsp;nat&nbsp;=&gt;&nbsp;f)&nbsp;n</string></coq_object><coq_object><list><string>Coq</string><string>Init</string><string>Peano</string></list><list><string>nat_rect_succ_r</string></list><string>forall&nbsp;(A&nbsp;:&nbsp;Type)&nbsp;(f&nbsp;:&nbsp;A&nbsp;-&gt;&nbsp;A)&nbsp;(x&nbsp;:&nbsp;A)&nbsp;(n&nbsp;:&nbsp;nat),
nat_rect&nbsp;(fun&nbsp;_&nbsp;:&nbsp;nat&nbsp;=&gt;&nbsp;A)&nbsp;x&nbsp;(fun&nbsp;_&nbsp;:&nbsp;nat&nbsp;=&gt;&nbsp;f)&nbsp;(S&nbsp;n)&nbsp;=
nat_rect&nbsp;(fun&nbsp;_&nbsp;:&nbsp;nat&nbsp;=&gt;&nbsp;A)&nbsp;(f&nbsp;x)&nbsp;(fun&nbsp;_&nbsp;:&nbsp;nat&nbsp;=&gt;&nbsp;f)&nbsp;n</string></coq_object></list></value>
-cj
On Tue, Oct 4, 2016 at 9:49 PM, zjhsdtc <zjhsdtc AT gmail.com> wrote:
Hi all,
There is something that has confused me for quite a while. if we use coqtop -ideslave --help-XML-protocol, it will produce a list of commands available in the ideslave, e.g. the Goal command, so we can simply send <call val="Goal"><unit/></call> to ideslave, i can easily play around with these commands except the Search one.
According to the brief documentation, it seems have to send a list of search constraint and boolean value pairs inside <call val="Search">...</call>, but after trying and failing for many times, i still can not find a way to construct a qualified xml message to stand for a search command.
So is there any examples to use Search command in ideslave or anyone have an idea how to use it?
Thank you,
