coq-club - Re: [Coq-Club] Stumped by a perfectly good looking definition in Chilpala's CPDT
  • To: Satrajit Roy <satrajit.roy AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Stumped by a perfectly good looking definition in Chilpala's CPDT
  • Date: Mon, 17 Oct 2016 13:18:36 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jwiegley AT gmail.com; spf=Pass smtp.mailfrom=jwiegley AT gmail.com; spf=None smtp.helo=postmaster AT mail-pf0-f172.google.com
  • Ironport-phdr: 9a23:wpD1zxw8J8SGo+/XCy+O+j09IxM/srCxBDY+r6Qd0esRIJqq85mqBkHD//Il1AaPBtSBra8ewLON4uigATVGusnR9ihaMdRlbFwst4Y/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbsy8IIPZjty22uau4NWTJlwQ3HvuKY91eS6/sR/YtMgKybFlO+5l0RLVuHJKevgQ32R5DV2Wlhf4oMy3+cgw3T5Xvqdr1clAV+3Ffqk3SbFJRnxyMWc14tLDsxTcRBGT52AVVH5QmR1NVVuWpCrmV4v853Op/tF23zOXaIivFeg5
  • Organization: New Artisans LLC
>>>>> "SR" == Satrajit Roy
>>>>> writes:
SR> My exposure to COQ is limited; so I'm possibly not seeing something
SR> obvious. Given the following definitions, why isn't the last one working?
After a few changes, this works. What you wrote failed to type check, not
because of the TNConst case, but because the type of the term you were
creating in the TBinop case was not the correct type, and this affected the
type expected for the TNConst case.
--8<---------------cut here---------------start------------->8---
Require Import Bool.Bool Arith List.
Inductive type:Set:=Nat|Bool.
Inductive tbinop:type->type->type->Set:=
|TPlus:tbinop Nat Nat Nat
|TTimes:tbinop Nat Nat Nat
|TEq:forall t, tbinop t t Bool
|Tlt:tbinop Nat Nat Bool.
Inductive texp:type->Set:=
|TNConst:nat->texp Nat
|TBConst:bool->texp Bool
|TBinop:forall t1 t2 t, tbinop t1 t2 t->texp t1->texp t2->texp t.
Definition typeDenote(t:type):Set:=
match t with
|Nat=>nat
|Bool=>bool
end.
Definition tbinopDenote arg1 arg2 res(b:tbinop arg1 arg2 res):typeDenote
arg1->typeDenote arg2->typeDenote res:=
match b with
|TPlus=>plus
|TTimes=>mult
|TEq Nat=>beq_nat
|TEq Bool=>eqb
|TLt=>leb
end.
Fixpoint texpDenote t (e:texp t):typeDenote t:=
match e with
|TNConst n=>n
|TBConst b=>b
|TBinop _ _ _ b e1 e2=> tbinopDenote _ _ _ b (texpDenote _ e1)
(texpDenote _ e2)
end.
--8<---------------cut here---------------end--------------->8---
John Wiegley GPG fingerprint = 4710 CF98 AF9B 327B B80F
http://newartisans.com 60E1 46C4 BD1A 7AC1 4BA2
