Re: [Coq-Club] Stumped by a perfectly good looking definition in Chilpala's CPDT
- To: coq-club AT inria.fr
- Cc: Satrajit Roy <satrajit.roy AT gmail.com>
- Subject: Re: [Coq-Club] Stumped by a perfectly good looking definition in Chilpala's CPDT
- Date: Tue, 18 Oct 2016 15:39:34 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=dfrumin AT cs.ru.nl; spf=None smtp.mailfrom=dan AT ip-145-116-189-16.wlan-int.ru.nl; spf=None smtp.helo=postmaster AT ip-145-116-189-16.wlan-int.ru.nl
- Ironport-phdr: 9a23:Z7bxMx0NKdwm0SIqsmDT+DRfVm0co7zxezQtwd8ZsegSLPad9pjvdHbS+e9qxAeQG96KsbQZ16GI6OjJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL2PbrnD61zMOABK3bVMzfbWvXNOOxJrsn8mJuLTrKz1SgzS8Zb4gZD6Xli728vcsvI15N6wqwQHIqHYbM85fxGdvOE7B102kvpT41NdZ/i9Ro/Ms8dJbGeW/JvxgDO8QMDNzOGcsocbvqBPrTA2V53JaXH9FvABPBl3p5ReycI3styr8/r5x1jOHOMzwZbsvHy6/qaFvHky7wBwbPiI0pTmEwvd7i7hW9Vf4/0Ry
Dear Satrajit,
Perhaps it would help do declare all the arguments representing types
in your functions as implicit. For instance:
Arguments texpDenote {t} e.
Arguments TBinop {t1 t2 t} op a1 a2.
Eval simpl in texpDenote (TNConst 42).
Eval simpl in texpDenote (TBinop TTimes (TNConst 42) (TNConst 2)).
Alternatively you can define ceratin arguments as implicit directly when
defining your function.
For instance:
Fixpoint texpDenote {t} (e:texp t):typeDenote t:=
match e with
|TNConst n=>n
|TBConst b=>b
|TBinop r1 r2 r b e1 e2=>
tbinopDenote r1 r2 r b (texpDenote e1) (texpDenote e2)
end.
Kind regards, - Dan
On 10/18, Satrajit Roy wrote:
It seems like a version incompatibility though, doesn't it?
Now I must use ugly syntax like the following:
Eval simpl in texpDenote _ (TNConst 42).
Eval simpl in texpDenote _ (TBConst true).
Eval simpl in texpDenote _ (TBinop _ _ _ TTimes (TBinop _ _ _ TPlus
(TNConst 2)(TNConst 2))(TNConst 7)).
Eval simpl in texpDenote _ (TBinop _ _ _ (TEq Nat) (TBinop _ _ _ TPlus
(TNConst 2) (TNConst 2))(TNConst 7)).
Eval simpl in texpDenote _ (TBinop _ _ _ TLt (TBinop _ _ _ TPlus (TNConst
I remember I executed parts of CPDT before and most things worked.
On Mon, Oct 17, 2016 at 4:43 PM, Satrajit Roy
wrote:
Ahhh!!! Thank you so much!!
On Mon, Oct 17, 2016 at 4:18 PM, John Wiegley
<johnw AT newartisans.com>
wrote:
>>>>> "SR" == Satrajit Roy
writes:
SR> My exposure to COQ is limited; so I'm possibly not seeing something
SR> obvious. Given the following definitions, why isn't the last one
working?
After a few changes, this works. What you wrote failed to type check, not
because of the TNConst case, but because the type of the term you were
creating in the TBinop case was not the correct type, and this affected
the
type expected for the TNConst case.
--8<---------------cut here---------------start------------->8---
Require Import Bool.Bool Arith List.
Inductive type:Set:=Nat|Bool.
Inductive tbinop:type->type->type->Set:=
|TPlus:tbinop Nat Nat Nat
|TTimes:tbinop Nat Nat Nat
|TEq:forall t, tbinop t t Bool
|Tlt:tbinop Nat Nat Bool.
Inductive texp:type->Set:=
|TNConst:nat->texp Nat
|TBConst:bool->texp Bool
|TBinop:forall t1 t2 t, tbinop t1 t2 t->texp t1->texp t2->texp t.
Definition typeDenote(t:type):Set:=
match t with
|Nat=>nat
|Bool=>bool
end.
Definition tbinopDenote arg1 arg2 res(b:tbinop arg1 arg2 res):typeDenote
arg1->typeDenote arg2->typeDenote res:=
match b with
|TPlus=>plus
|TTimes=>mult
|TEq Nat=>beq_nat
|TEq Bool=>eqb
|TLt=>leb
end.
Fixpoint texpDenote t (e:texp t):typeDenote t:=
match e with
|TNConst n=>n
|TBConst b=>b
|TBinop _ _ _ b e1 e2=> tbinopDenote _ _ _ b (texpDenote _ e1)
(texpDenote _ e2)
end.
--8<---------------cut here---------------end--------------->8---
John Wiegley GPG fingerprint = 4710 CF98 AF9B 327B B80F
http://newartisans.com 60E1 46C4 BD1A 7AC1 4BA2
Satrajit
Satrajit
- [Coq-Club] Stumped by a perfectly good looking definition in Chilpala's CPDT, Satrajit Roy, 10/17/2016
- Re: [Coq-Club] Stumped by a perfectly good looking definition in Chilpala's CPDT, John Wiegley, 10/17/2016
- Re: [Coq-Club] Stumped by a perfectly good looking definition in Chilpala's CPDT, Satrajit Roy, 10/17/2016
- Re: [Coq-Club] Stumped by a perfectly good looking definition in Chilpala's CPDT, Satrajit Roy, 10/18/2016
- Re: [Coq-Club] Stumped by a perfectly good looking definition in Chilpala's CPDT, Dan Frumin, 10/18/2016
- Re: [Coq-Club] Stumped by a perfectly good looking definition in Chilpala's CPDT, Tej Chajed, 10/18/2016
- Re: [Coq-Club] Stumped by a perfectly good looking definition in Chilpala's CPDT, Satrajit Roy, 10/19/2016
- Re: [Coq-Club] Stumped by a perfectly good looking definition in Chilpala's CPDT, Hugo Herbelin, 10/20/2016
