coq-club - [Coq-Club] Universe inconsistencies introduced by canonical structures
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Universe inconsistencies introduced by canonical structures
  • Date: Fri, 21 Oct 2016 16:56:09 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=forster AT ps.uni-saarland.de; spf=None smtp.mailfrom=forster AT ps.uni-saarland.de; spf=None smtp.helo=postmaster AT triton.rz.uni-saarland.de
  • Importance: Normal
  • Ironport-phdr: 9a23:B5y6PxKpEls+eH1jVdmcpTZWNBhigK39O0sv0rFitYgXLP7xwZ3uMQTl6Ol3ixeRBMOAuqgC1bKd7PCoGTRZp83e4DZaKN0EfiRGoPtVtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdaymUrLV2s+wzqW5/4DZSwROnju0J71ofzusqgCEuM4MmpdvMI4p0V3UpHoNYO1f32dhI17VkxuvtY+L4Jd//nEI6Loa/MlaXPCicg==
Dear coq-club,
while playing around with Canonical Structures (mainly to find out if we
want to use eqTypes in our lecture and the accompanying exercises) I am
running into weird universe inconsistencies.
I condensed the issue to a minimal example (which looks a bit unnatural,
but it's just to produce the error). Assume I have a structure that has a
type enclosed, plus usually some additional stuff (for instance the fact
that equality on this type is decidable if we're talking about eqTypes)
and a straightforward Canonical Structure for it.
Structure wrap :=
Wrap {
type :> Type;
(* here's normally a typeclass with function type, so this has to be
a structure *)
Canonical Structure do_wrap (X : Type) := Wrap X.
I'll use the following two lemmas to make the problem clear:
Lemma trivial1 (X: wrap) (x : X) : True.
Proof.
tauto.
Qed.
Lemma trivial2 (X: Type) (x : X) : True.
Proof.
tauto.
Qed.
And now the following explains the problem:
Lemma should_be_trivial (X : wrap) : forall (x : list X), True.
Proof.
eapply trivial1.
Show Proof.
Fail Qed.
(* The command has indeed failed with message: *)
(* Illegal application: *)
(* The term "do_wrap" of type "forall _ : Type@{Top.35}, wrap" *)
(* cannot be applied to the term *)
(* "list (eqType_X X)" : "Type@{max(Set, Top.34)}" *)
(* This term has type "Type@{max(Set, Top.34)}" which should be coercible
to "Type@{Top.35}". *)
Restart.
eapply trivial2.
Fail Fail Qed. (* this is universe consistent, Qed would work! *)
Restart.
eapply trivial1 with (X := Wrap (list X)).
Fail Fail Qed. (* Qed would work here, which is not surprising *)
Restart.
eapply trivial1 with (X := do_wrap (list X)).
Qed. (* Qed works. This looks surprising to me *)
For some reason, the implicit use of the canonical structure when applying
trivial1 introduces a universe inconsistency. Not using the canonical
structure at all works flawlessly.
Also not very surprising, if I apply trivial1 and do the work of the Can.
Structure by hand, it works. So I thought, ok, maybe the Canonical
Structure (Wrap in this case) is not Template Universe polymorphic (it's
really not) and that's why this doesn't work.
However, if I apply the Structure by hand, unfolded, it also works. So
somewhere during finding out which Canonical Structure to use, there's a
universe inconsistency introduced.
Is this a bug, or somehow intended behaviour?
Many thanks in advance
Yannick
PS: Here the complete source code of the example, if you want to try it:
Structure wrap :=
Wrap {
type :> Type;
a structure *)
Universe Polymorphic do_wrap. (* this does nothing *)
Proof.
tauto.
Qed.
Proof.
tauto.
Qed.
Set Printing Universes.
Set Printing All.
Proof.
eapply trivial1.
Show Proof.
Fail Qed.
Restart.
eapply trivial2.
Restart.
Restart.
