- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Universe inconsistencies introduced by canonical structures
- Date: Fri, 21 Oct 2016 17:18:35 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mail AT maximedenes.fr; spf=Pass smtp.mailfrom=mail AT maximedenes.fr; spf=None smtp.helo=postmaster AT 2.mo2.mail-out.ovh.net
- Ironport-phdr: 9a23:WeL4Kx/cWnmiMf9uRHKM819IXTAuvvDOBiVQ1KB90eMcTK2v8tzYMVDF4r011RmSDN+dtaoP27OempujcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47AblHf6ke/8SQVUk2mc1EkfKKrQsWC1oye7KObw9XreQJGhT6wM/tZDS6dikHvjPQQmpZoMa0ryxHE8TNicuVSwn50dxrIx06vrpT4wJk2+CNJ/vkl6sRoUKPgfq1+Q6YLIi4hNjUQ7d3qsBSLYYqJZmBUBmAfkx5gBgHV7RT3Upr3vzC8uPAri3rSBtH/Ub1hAWfq1KxsUhK90Co=
Hello,
It looks like a bug.
The canonical structure inference probably forgets a universe
constraint. I wouldn't be surprised if it is related to the insertion of
the coercion to Type.
Can you submit a bug report at : https://coq.inria.fr/bugs/ ?
Thanks!
Maxime.
On 10/21/16 16:56,
forster AT ps.uni-saarland.de
wrote:
> Dear coq-club,
> while playing around with Canonical Structures (mainly to find out if we
> want to use eqTypes in our lecture and the accompanying exercises) I am
> running into weird universe inconsistencies.
> I condensed the issue to a minimal example (which looks a bit unnatural,
> but it's just to produce the error). Assume I have a structure that has a
> type enclosed, plus usually some additional stuff (for instance the fact
> that equality on this type is decidable if we're talking about eqTypes)
> and a straightforward Canonical Structure for it.
> Structure wrap :=
> Wrap {
> type :> Type;
> (* here's normally a typeclass with function type, so this has to be
> a structure *)
> Canonical Structure do_wrap (X : Type) := Wrap X.
> I'll use the following two lemmas to make the problem clear:
> Lemma trivial1 (X: wrap) (x : X) : True.
> Proof.
> tauto.
> Qed.
> Lemma trivial2 (X: Type) (x : X) : True.
> Proof.
> tauto.
> Qed.
> And now the following explains the problem:
> Lemma should_be_trivial (X : wrap) : forall (x : list X), True.
> Proof.
> eapply trivial1.
> Show Proof.
> Fail Qed.
> (* The command has indeed failed with message: *)
> (* Illegal application: *)
> (* The term "do_wrap" of type "forall _ : Type@{Top.35}, wrap" *)
> (* cannot be applied to the term *)
> (* "list (eqType_X X)" : "Type@{max(Set, Top.34)}" *)
> (* This term has type "Type@{max(Set, Top.34)}" which should be coercible
> to "Type@{Top.35}". *)
> Restart.
> eapply trivial2.
> Fail Fail Qed. (* this is universe consistent, Qed would work! *)
> Restart.
> eapply trivial1 with (X := Wrap (list X)).
> Fail Fail Qed. (* Qed would work here, which is not surprising *)
> Restart.
> eapply trivial1 with (X := do_wrap (list X)).
> Qed. (* Qed works. This looks surprising to me *)
> For some reason, the implicit use of the canonical structure when applying
> trivial1 introduces a universe inconsistency. Not using the canonical
> structure at all works flawlessly.
> Also not very surprising, if I apply trivial1 and do the work of the Can.
> Structure by hand, it works. So I thought, ok, maybe the Canonical
> Structure (Wrap in this case) is not Template Universe polymorphic (it's
> really not) and that's why this doesn't work.
> However, if I apply the Structure by hand, unfolded, it also works. So
> somewhere during finding out which Canonical Structure to use, there's a
> universe inconsistency introduced.
> Is this a bug, or somehow intended behaviour?
> Many thanks in advance
> Yannick
> PS: Here the complete source code of the example, if you want to try it:
> Structure wrap :=
> Wrap {
> type :> Type;
> a structure *)
> Universe Polymorphic do_wrap. (* this does nothing *)
> Proof.
> tauto.
> Qed.
> Proof.
> tauto.
> Qed.
> Set Printing Universes.
> Set Printing All.
> Proof.
> eapply trivial1.
> Show Proof.
> Fail Qed.
> Restart.
> eapply trivial2.
> Restart.
> Restart.
- [Coq-Club] Universe inconsistencies introduced by canonical structures, forster, 10/21/2016
- Re: [Coq-Club] Universe inconsistencies introduced by canonical structures, Maxime Dénès, 10/21/2016
- Re: [Coq-Club] Universe inconsistencies introduced by canonical structures, Matthieu Sozeau, 10/21/2016
