- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq 8.6 typeclasses behavior change
- Date: Wed, 16 Nov 2016 13:47:35 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f41.google.com
- Ironport-phdr: 9a23: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
I'm curious about the actual use cases of using such non-class premises around, I'd be happy to hear about others. We can still go back on this cleanup.
-- Matthieu
On Wed, Nov 16, 2016 at 2:40 PM Matthieu Sozeau <mattam AT mattam.org> wrote:
The goal is to be able to recognize what is and what isn't a class goal from its type.When doing resolution during refinement we need that information.One can also argue that if you put Hint Extern (_ = _) => reflexivity : typeclass_instancesin your file then you can expect Definition foo : 0 = 0 := _. to typecheck.-- MatthieuOn Wed, Nov 16, 2016 at 2:33 PM Enrico Tassi <enrico.tassi AT inria.fr> wrote:On Wed, Nov 16, 2016 at 01:23:04PM +0000, Matthieu Sozeau wrote:
> This is a deliberate change to avoid "wrong" instances which generate
> non-class goals from polluting search.
> You just need to declare the head as a class using Existing Class eq for
> example here, because you're really
> treating it as a class. Sorry for not updating the CHANGES yet, the refman
> has been updated though.
What you propose seems a bit too drastic, Existing Class marks
Eq as class "forever". A lighter work around could be the following
Class Foo (x : nat).
Class TCPremise (P : Prop).
Instance foo x : TCPremise (x = 2) -> Foo x.
Hint Extern 0 (TCPremise (_ = _)) => reflexivity : typeclass_instances.
But frankly the use case of Ralf seems reasonable, and the contortion
above pretty ugly.
Can you explain what you mean by "wrong" instances, exactly?
Best,
Enrico Tassi
- [Coq-Club] Coq 8.6 typeclasses behavior change, Ralf Jung, 11/16/2016
- Re: [Coq-Club] Coq 8.6 typeclasses behavior change, Matthieu Sozeau, 11/16/2016
- Re: [Coq-Club] Coq 8.6 typeclasses behavior change, Enrico Tassi, 11/16/2016
- Re: [Coq-Club] Coq 8.6 typeclasses behavior change, Jonathan Leivent, 11/16/2016
- Re: [Coq-Club] Coq 8.6 typeclasses behavior change, Robbert Krebbers, 11/16/2016
