- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq 8.6 typeclasses behavior change
- Date: Wed, 16 Nov 2016 20:42:12 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mailinglists AT robbertkrebbers.nl; spf=None smtp.mailfrom=mailinglists AT robbertkrebbers.nl; spf=None smtp.helo=postmaster AT smtp1.science.ru.nl
- Ironport-phdr: 9a23:rGX+kxyF8nMKgEfXCy+O+j09IxM/srCxBDY+r6Qd0uIRIJqq85mqBkHD//Il1AaPBtSArasYwLOM7eigATVGusnR9ihaMdRlbFwst4Y/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbre9JomHhMOukuu25pf7YgNShTP7b6khAg+xqFDrscMcjJF+YoUrxxHDr2FTM7BTzGJsJFScmxfn+tyY5plp+SlKp/E7+sRKXL/hOaI8G+8LRA86Onw4sZW4/SLIShGCsyMR
In the Iris library, we have some type classes that have a boolean premise (for example, an expression being physically atomic, which we can easily solve by computation).
If we want to handle this the way you suggested, we have to declare Is_true : bool -> Prop as an Existing Class, which causes other problems. For example, when having normal Is_true premises of other lemmas, the ssreflect rewrite tactic will fail (because it cannot find a type class instance) instead of generating a goal.
Enrico's suggestion could work, and sounds better than our current workaround in Ralf's initial message in this thread.
On 11/16/2016 02:47 PM, Matthieu Sozeau wrote:
I'm curious about the actual use cases of using such non-class premises
around, I'd be happy to hear about others. We can still go back on this
cleanup.
-- Matthieu
On Wed, Nov 16, 2016 at 2:40 PM Matthieu Sozeau
<mattam AT mattam.org
<mailto:mattam AT mattam.org>>
wrote:
The goal is to be able to recognize what is and what isn't a class
goal from its type.
When doing resolution during refinement we need that information.
One can also argue that if you put Hint Extern (_ = _) =>
reflexivity : typeclass_instances
in your file then you can expect Definition foo : 0 = 0 := _. to
typecheck.
-- Matthieu
On Wed, Nov 16, 2016 at 2:33 PM Enrico Tassi
<enrico.tassi AT inria.fr
<mailto:enrico.tassi AT inria.fr>>
wrote:
On Wed, Nov 16, 2016 at 01:23:04PM +0000, Matthieu Sozeau wrote:
> This is a deliberate change to avoid "wrong" instances which
generate
> non-class goals from polluting search.
> You just need to declare the head as a class using Existing
Class eq for
> example here, because you're really
> treating it as a class. Sorry for not updating the CHANGES
yet, the refman
> has been updated though.
What you propose seems a bit too drastic, Existing Class marks
Eq as class "forever". A lighter work around could be the following
Class Foo (x : nat).
Class TCPremise (P : Prop).
Instance foo x : TCPremise (x = 2) -> Foo x.
Hint Extern 0 (TCPremise (_ = _)) => reflexivity :
typeclass_instances.
But frankly the use case of Ralf seems reasonable, and the
contortion
above pretty ugly.
Can you explain what you mean by "wrong" instances, exactly?
Best,
Enrico Tassi
- [Coq-Club] Coq 8.6 typeclasses behavior change, Ralf Jung, 11/16/2016
- Re: [Coq-Club] Coq 8.6 typeclasses behavior change, Matthieu Sozeau, 11/16/2016
- Re: [Coq-Club] Coq 8.6 typeclasses behavior change, Enrico Tassi, 11/16/2016
- Re: [Coq-Club] Coq 8.6 typeclasses behavior change, Jonathan Leivent, 11/16/2016
- Re: [Coq-Club] Coq 8.6 typeclasses behavior change, Robbert Krebbers, 11/16/2016
