- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coercion of Fixpoint-defined elements of a Type Class
- Date: Thu, 17 Nov 2016 07:07:28 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=amintimany AT gmail.com; spf=Pass smtp.mailfrom=amintimany AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f51.google.com
- Ironport-phdr: 9a23:+gMYiR1ylmE/J9gJsmDT+DRfVm0co7zxezQtwd8Zse0UL/ad9pjvdHbS+e9qxAeQG96KsLQd1qGG7ejJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fdbghMijexe65+IRW5oQjSt8QdnJdvJLs2xhbVuHVDZv5YxXlvJVKdnhb84tm/8Zt++ClOuPwv6tBNX7zic6s3UbJXAjImM3so5MLwrhnMURGP5noHXWoIlBdDHhXI4wv7Xpf1tSv6q/Z91SyHNsD4Ubw4RTKv5LptRRT1iikIKiQ5/XnXhMNsg6xUrw+vqRJxw4DKYo6bN/1wc7jBfdMDQGpNQsZRWzBDD466coABD/ABPeFdr4Tlu1YOqBq+BQ+xD+3xyz9Ig2X53as60u88FgzJxgkgH9MIsHTIrdX1Mb0dUea1zaTTwjXDaulZ2Tb56ITSbh8hpvSMUKt2fMHMykcvDxvIg1efpID/Ij+ZyOQAv3KY4uZ+T+6ii3MrpxlyrzWh3MshjpTFipgRx1za7yl13YQ4KcG+RUVme9CrCoFQuDufN4ZuQsMtXWVouCEix70Do5G7fSwKxI0pxh7ad/CLaoaI7xL+WOqLLjd4g3VleL27hxms60Sv1ur8Vsys3FZLqCpKjMXMu2gP2hHc8MSLV+Vx80e71TuMyQzf8OFJLV0smareMZEhw7owlpQJsUTEGy/7gF/5jKqXdkUi5uio6uHnba/gpp6cLIJ0hQT+Pb4vmsy7G+g3Lg8OX22D9eSmyLLj5VH5QKlNjvAujqbZt4naKd0Hqa69Hg9ayZ0u6w2/DjejyNQXh2MLLFNDeBKdjojmIUvCIP7iDaT3v1P5mzBygvvCI7fJA5PXL3GFnq2yU6x67ht1zQs1hexe4ptSG/lVKffyXFPwsdXeHzc2NgW1x6DsD9ArhdBWYn6GHqLMaPCailSP/O96e+Q=
Hi Polina,
Instead of the nthProd, you can use the following alternative definition:
Require Import Categories.Essentials.Notations.
Require Import Categories.Category.Category.
Require Import Categories.Basic_Cons.CCC.
Section nth_Prod.
Context {C : Category} {HT: Terminal C} {HP: Has_Products C}.
Record nth_ProdT :=
{ npT : Type; npel:> npT; npobj : npT → C}.
Fixpoint nth_Prod (A : C) (n : nat) : nth_ProdT :=
match n with
| O => {| npT := (Terminal C); npel := HT; npobj := terminal |}
| S m =>
{| npT := Product A (npobj (nth_Prod A m) (nth_Prod A m));
npel := HP A (npobj (nth_Prod A m) (nth_Prod A m));
npobj := product _ _ |}
end.
Definition nth_Prod_obj (np : nth_ProdT) : C := npobj np np.
Coercion nth_Prod_obj : nth_ProdT >-> Obj.
Fixpoint arrow_to_nthProd (A B : C) (f : (A –≻ B)%morphism) (n : nat) :
(A –≻ (nth_Prod B n))%morphism :=
match n with
| O => t_morph _ _
| S m => Prod_morph_ex _ _ f (arrow_to_nthProd A B f m)
end.
End nth_Prod.
Notice that here I have defined a type nth_ProdT which doesn’t directly
include the object that you want (the n-fold product of an object). Instead
it comes with a type which depending on n in nth_Prod can be a Terminal (the
complete record) or a Product (the complete record) of A and the object
computed from the lower level (m in case n = S m). It also includes an
element of this type and a way to get an object out of this element. This
way, you can keep the information you want around, e.g., the unique morphism
to the terminal object (t_morph above) the projections of product, etc. You
can use this to for example define something lie arrow_to_nthProd above.
Regards,
Amin
> On 17 Nov 2016, at 04:36, Polina Vinogradova
> <polina.vino AT gmail.com>
> wrote:
> Hello !
> I am trying to build a coercion that would allow me to apply the projection
> function found in the Product Type Class (category-theoretic notion
> thereof) to an n-fold product of an object A (in a category).
> I need to to build a function akin to
> Fixpoint func (A B:Obj) ( m:nat) ( f: B Hom (nthProd A m) )
> ( ... other parameters) : Prop :=
> match m with
> | 0 => ..
> | S m' => ..
> | S (S m') => func A (S m') (compose f Pi_2) ...
> end.
> for this , I need
> (nthProd A (S (S m))) : (Product A (nthProd A (S m)))
> (but it is merely of type Obj)
> or something like that, so that
> f : Hom B (Product A (nthProd A (S m)))
> (compose f Pi_2) : Hom B (nthProd A (S m))
> Alternatively, I need to build a function Pi_2' that would take the
> available arguments and produce a map of the right type to recursively call
> func with. Here, nthProd is
> Fixpoint nthProd (A : RC) (n : nat) : Obj :=
> match n with
> | 0 => termial_obj
> | S 0 => A
> | S m => (Has_Products A (nthProd A m))
> end.
> I have been trying to work this out for a while now and I would really
> appreciate any ideas on defining the appropriate coercions or avoiding this
> problem in some other way!
> Thank you!
> Polina
- [Coq-Club] Coercion of Fixpoint-defined elements of a Type Class, Polina Vinogradova, 11/17/2016
- Re: [Coq-Club] Coercion of Fixpoint-defined elements of a Type Class, Amin Timany, 11/17/2016
- Re: [Coq-Club] Coercion of Fixpoint-defined elements of a Type Class, Polina Vinogradova, 11/17/2016
