- From: Polina Vinogradova <polina.vino AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coercion of Fixpoint-defined elements of a Type Class
- Date: Thu, 17 Nov 2016 13:41:25 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=polina.vino AT gmail.com; spf=Pass smtp.mailfrom=polina.vino AT gmail.com; spf=None smtp.helo=postmaster AT mail-it0-f49.google.com
- Ironport-phdr: 9a23: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
Thank you so much! This helps a lot. I was hoping to avoid building additional structures but i think you are right, this is the way to go.
Polina
On Thu, Nov 17, 2016 at 1:07 AM, Amin Timany <amintimany AT gmail.com> wrote:
Hi Polina,
Instead of the nthProd, you can use the following alternative definition:
Require Import Categories.Essentials.Notations.
Require Import Categories.Category.Category.
Require Import Categories.Basic_Cons.CCC.
Section nth_Prod.
Context {C : Category} {HT: Terminal C} {HP: Has_Products C}.
Record nth_ProdT :=
{ npT : Type; npel:> npT; npobj : npT → C}.
Fixpoint nth_Prod (A : C) (n : nat) : nth_ProdT :=
match n with
| O => {| npT := (Terminal C); npel := HT; npobj := terminal |}
| S m =>
{| npT := Product A (npobj (nth_Prod A m) (nth_Prod A m));
npel := HP A (npobj (nth_Prod A m) (nth_Prod A m));
npobj := product _ _ |}
end.
Definition nth_Prod_obj (np : nth_ProdT) : C := npobj np np.
Coercion nth_Prod_obj : nth_ProdT >-> Obj.
Fixpoint arrow_to_nthProd (A B : C) (f : (A –≻ B)%morphism) (n : nat) :
(A –≻ (nth_Prod B n))%morphism :=
match n with
| O => t_morph _ _
| S m => Prod_morph_ex _ _ f (arrow_to_nthProd A B f m)
end.
End nth_Prod.
Notice that here I have defined a type nth_ProdT which doesn’t directly include the object that you want (the n-fold product of an object). Instead it comes with a type which depending on n in nth_Prod can be a Terminal (the complete record) or a Product (the complete record) of A and the object computed from the lower level (m in case n = S m). It also includes an element of this type and a way to get an object out of this element. This way, you can keep the information you want around, e.g., the unique morphism to the terminal object (t_morph above) the projections of product, etc. You can use this to for example define something lie arrow_to_nthProd above.
Regards,
Amin
> On 17 Nov 2016, at 04:36, Polina Vinogradova <polina.vino AT gmail.com> wrote:
> Hello !
> I am trying to build a coercion that would allow me to apply the projection function found in the Product Type Class (category-theoretic notion thereof) to an n-fold product of an object A (in a category).
> I need to to build a function akin to
> Fixpoint func (A B:Obj) ( m:nat) ( f: B Hom (nthProd A m) )
> ( ... other parameters) : Prop :=
> match m with
> | 0 => ..
> | S m' => ..
> | S (S m') => func A (S m') (compose f Pi_2) ...
> end.
> for this , I need
> (nthProd A (S (S m))) : (Product A (nthProd A (S m)))
> (but it is merely of type Obj)
> or something like that, so that
> f : Hom B (Product A (nthProd A (S m)))
> (compose f Pi_2) : Hom B (nthProd A (S m))
> Alternatively, I need to build a function Pi_2' that would take the available arguments and produce a map of the right type to recursively call func with. Here, nthProd is
> Fixpoint nthProd (A : RC) (n : nat) : Obj :=
> match n with
> | 0 => termial_obj
> | S 0 => A
> | S m => (Has_Products A (nthProd A m))
> end.
> I have been trying to work this out for a while now and I would really appreciate any ideas on defining the appropriate coercions or avoiding this problem in some other way!
> Thank you!
> Polina
- [Coq-Club] Coercion of Fixpoint-defined elements of a Type Class, Polina Vinogradova, 11/17/2016
- Re: [Coq-Club] Coercion of Fixpoint-defined elements of a Type Class, Amin Timany, 11/17/2016
- Re: [Coq-Club] Coercion of Fixpoint-defined elements of a Type Class, Polina Vinogradova, 11/17/2016
