Re: [Coq-Club] What's the best way to extract programs that use random numbers?
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] What's the best way to extract programs that use random numbers?
- Date: Tue, 22 Nov 2016 15:43:52 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=ilmars.cirulis AT gmail.com; spf=Pass smtp.mailfrom=ilmars.cirulis AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f171.google.com
- Ironport-phdr: 9a23:PHt6QhesGdSrLWFsLAeB0CJ7lGMj4u6mDksu8pMizoh2WeGdxc2zbR7h7PlgxGXEQZ/co6odzbGH6Oa6BCdcsN7B6ClEK8McEUddyI0/pE8JPo2sMQXDNvnkbig3ToxpdWRO2DWFC3VTA9v0fFbIo3e/vnY4ExT7MhdpdKyuQtaBx5f/6+fnsZbUekBDgCe3SbJ0NhS/6wvL/IFCiox7b6011xHho31Seu0Qy3k+dnyJmBOpx8O1V4R4uw9Roe8l9tUIBaT+eq0iVvpTDS47N2EuzMLuvBjHCwCI4y1PAS0tjhNUDl2dv1nBVZDrv36iuw==
I did it.
> Lemma continuous2_app : forall `{c1:cpo D1} `{c2:cpo D2} `{c3:cpo D3}
> (F : D1 -m> D2 -m> D3) {cF:continuous2 F} (k:D1), continuous (F k).
> red; intros.
> transitivity (F (mlub (cte nat k)) (lub h)); auto.
> transitivity (lub ((F @2 (mon (cte nat k))) h)); auto.
> apply lub_le_compat; simpl; auto.
> Save.
On Tue, Nov 22, 2016 at 1:46 PM, Ilmārs Cīrulis <ilmars.cirulis AT gmail.com> wrote:
Using Coq 8.5, I get error in the file Ccpo.v (of Alea, version 8), line 1729> apply (fmonotonic2 F); auto.> Unable to unify "monotonic2 (fun2 F)" with> "(F (mlub cte nat k)) (lub h) <= lub (F k @ h)".
I will try to fix it myself, of course, but I will be thankful for any hints. :)On Mon, Nov 21, 2016 at 6:31 PM, Ilmārs Cīrulis <ilmars.cirulis AT gmail.com> wrote:Big thank you!Yes, it helps.It seems that Alea must be ported to Coq 8.5, but that seems easy to do. In progress.--IlmarsOn Mon, Nov 21, 2016 at 2:01 PM, Xavier Leroy <Xavier.Leroy AT inria.fr> wrote:On 11/21/2016 10:59 AM, Ilmārs Cīrulis wrote:
> I am thinking about the best way to use Coq for extracting correct programs
> that uses random numbers? (Preferably, into Haskell.)
> Is there some good library for such purposes? Or, if there's not, what's the
> best literature / articles to get useful insights.
You could certainly program (in Coq) using a probability monad, which
should extract nicely to Haskell or to Caml.
To formally reason about your probabilistic programs, the following
Coq libraries and tools could help:
- Alea https://www.lri.fr/~paulin/ALEA/
- Certicrypt http://certicrypt.gforge.inria.fr/
Hope this helps,
- Xavier Leroy
- [Coq-Club] What's the best way to extract programs that use random numbers?, Ilmārs Cīrulis, 11/21/2016
- Re: [Coq-Club] What's the best way to extract programs that use random numbers?, Ilmārs Cīrulis, 11/21/2016
- Re: [Coq-Club] What's the best way to extract programs that use random numbers?, Xavier Leroy, 11/21/2016
- Re: [Coq-Club] What's the best way to extract programs that use random numbers?, Ilmārs Cīrulis, 11/22/2016
