coq-club - Re: [Coq-Club] What's the best way to extract programs that use random numbers?
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] What's the best way to extract programs that use random numbers?
  • Date: Tue, 22 Nov 2016 20:31:38 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=ilmars.cirulis AT gmail.com; spf=Pass smtp.mailfrom=ilmars.cirulis AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f179.google.com
  • Ironport-phdr: 9a23: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
Successfully fixed (ported?) it for Coq 8.5 pl 3.
(except Rplus.v file.)
On Tue, Nov 22, 2016 at 3:43 PM, Ilmārs Cīrulis <ilmars.cirulis AT gmail.com> wrote:
I did it.
> Lemma continuous2_app : forall `{c1:cpo D1} `{c2:cpo D2} `{c3:cpo D3}
>            (F : D1 -m> D2 -m> D3) {cF:continuous2 F} (k:D1), continuous (F k).
> red; intros.
> transitivity  (F (mlub (cte nat k))  (lub h)); auto.
> transitivity (lub ((F @2 (mon (cte nat k))) h)); auto.
> apply lub_le_compat; simpl; auto.
> Save.
On Tue, Nov 22, 2016 at 1:46 PM, Ilmārs Cīrulis <ilmars.cirulis AT gmail.com> wrote:
Using Coq 8.5, I get error in the file Ccpo.v (of Alea, version 8), line 1729
> apply (fmonotonic2 F); auto.
> Unable to unify "monotonic2 (fun2 F)" with
>  "(F (mlub cte nat k)) (lub h) <= lub (F k @ h)".
I will try to fix it myself, of course, but I will be thankful for any hints. :)
On Mon, Nov 21, 2016 at 6:31 PM, Ilmārs Cīrulis <ilmars.cirulis AT gmail.com> wrote:
Big thank you!
Yes, it helps.
It seems that Alea must be ported to Coq 8.5, but that seems easy to do. In progress.
Ilmars
On Mon, Nov 21, 2016 at 2:01 PM, Xavier Leroy <Xavier.Leroy AT inria.fr> wrote:
On 11/21/2016 10:59 AM, Ilmārs Cīrulis wrote:
> I am thinking about the best way to use Coq for extracting correct programs
> that uses random numbers? (Preferably, into Haskell.)
> Is there some good library for such purposes? Or, if there's not, what's the
> best literature / articles to get useful insights.
You could certainly program (in Coq) using a probability monad, which
should extract nicely to Haskell or to Caml.
To formally reason about your probabilistic programs, the following
Coq libraries and tools could help:
- Alea  https://www.lri.fr/~paulin/ALEA/
- Certicrypt  http://certicrypt.gforge.inria.fr/
Hope this helps,
- Xavier Leroy
