coq-club - [Coq-Club] proving UIP on decidable domains
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] proving UIP on decidable domains
  • Date: Thu, 15 Dec 2016 09:05:16 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=iuhnuhceh AT gmail.com; spf=Pass smtp.mailfrom=iuhnuhceh AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f50.google.com
  • Ironport-phdr: 9a23:hoBdfRTF66BrTdXc7qDZ4vEi7tpsv+yvbD5Q0YIujvd0So/mwa67bBGN2/xhgRfzUJnB7Loc0qyN4vumBzNLvczJ8ChbNscTB1ld0YRetjdjKfDGIHWzFOTtYS0+EZYKf35e1Fb/D3JoHt3jbUbZuHy44G1aMBz+MQ1oOra9QdaK3IyS3uG2s6bLeQROi3L9Ouszf12KqlDasdBTio9/II4wzAHIqz1GYbd432RtcHmTghD8+8b43JMrpyVNu/Q898VNUY31eq05SfpTCzFwYDN939HiqRSWFVjH3XAbSGhDyUJF
Hi all,
I'm reading the proof of UIP on decidable domains in the standard
library of coq:
source: theories/Logic/Eqdep_dec.v
doc: https://coq.inria.fr/library/Coq.Logic.Eqdep_dec.html
The proof "eq_proofs_unicity_on" uses some definitions like "nu" and "nu_inv".
I think the proof is confusing, does anyone know the meaning of "nu"
and "nu_inv"?
I try to simplify the proof by inlining (see below).
I find we can use a projection instead of "nu" and "nu_inv".
maybe it seem cleaner than the original proof?
Thanks!
Chunhui
Section eqdep_dec.
Variable A : Type.
Variable A_dec : forall (x y : A), x = y \/ x <> y.
Definition or_proj {x' y : A} (oreq : x' = y \/ x' <> y)
(x : A) (def : x = y) : x = y :=
match oreq with
| or_introl H =>
match A_dec x' x with
| or_introl e =>
match e in _ = y' return y' = y with
| eq_refl => H
end
| or_intror _ => def
end
| or_intror _ => def
end.
Lemma or_proj_eq : forall {x y : A} (u : x = y), or_proj (A_dec x y) x u =
u.
Proof.
intros x y u.
unfold or_proj.
case u.
case (A_dec x x) as [Heq | Hneq].
{ case Heq. apply eq_refl. }
{ exfalso; apply (Hneq eq_refl). }
Qed.
Theorem eq_proofs_unicity : forall {x y : A} (p1 p2 : x = y), p1 = p2.
Proof.
intros x y p1 p2.
case (or_proj_eq p1).
case (or_proj_eq p2).
unfold or_proj.
case (A_dec x y) as [Heq | Hneq].
{ case (A_dec x x) as [Heq' | Hneq'] .
{ apply eq_refl. }
{ exfalso; apply (Hneq' eq_refl). } }
{ exfalso; apply (Hneq p1). }
Qed.
End eqdep_dec.
