coq-club - Re: [Coq-Club] proving UIP on decidable domains
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] proving UIP on decidable domains
  • Date: Thu, 15 Dec 2016 10:19:08 +0000
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=iuhnuhceh AT gmail.com; spf=Pass smtp.mailfrom=iuhnuhceh AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f51.google.com
  • Ironport-phdr: 9a23:wAnlkRKFzcZGmFbUQ9mcpTZWNBhigK39O0sv0rFitYgRL/rxwZ3uMQTl6Ol3ixeRBMOAuqkC1bqd6/yocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXdrXKo8DEdBAj0OxZrKeTpAI7SiNm82/yv95HJbQhFgDSwbalzIRi1ogndqsYbipZ+J6gszRfEvmFGcPlMy2NyIlKTkRf85sOu85Nm7i9dpfEv+dNeXKvjZ6g3QqBWAzogM2Au+c3krgLDQheV5nsdSWoZjBxFCBXY4R7gX5fxtiz6tvdh2CSfIMb7Q6w4VSik4qx2TxHnkiYHNzok+2/KksxwlqNboBSupxdix4LZbp2ZOP94c6jAf90VWHBBU95TWCxPAo2yYYgBAfcfM+lEtIT9u0cCoAGiCQWwGO/iyDlFjWL2060g1OQhFBnL0RIgH9ITtnTUrMj1NKYPWu630qbD0DLOb/JL2Tf97ojIbxAhru2SUrJwasfRxkwvGBnEjlWUs4DqIzSV1uEUvmWd8uFuW+Wvi2s9pAFwpDii3sYsio/ThoIU0F/I7yt5wJwzKNalS0B7ecapHIVMuyyeLYd7QcMvT3t2tConybAKo562cDUMxZ863RDQceaHfJKN4h/7VOaePzN4hHV9dbK6nRmy8EygxvT7Vsm1zFpGtyRFn9nRunwX2BzT7c+HSvR5/ki/wzqAywfT6uRcLUA1k6rUNYIhz6YumpYPtUnPBCz7lUXsgKOIa0kp+fKk5uT6brn+o5+TLY50igXwMqQ0ncy/BPw1MgkTX2ib/+S8yb3j8lHnT7VKlfA2nazZv4rbJcQfvKK2HwhV0oM75xalEzimyMgYnWUALF9dZB2HiJHpN0jSL/D8EPewmE+hkCxrxvDDJr3uGI/BLnnFkLf7fLZy8VRQyAQpzYMX25UBAbYYZfn3R0XZtdrCDxZ/PRbn7fzgDYBW1p4YWX+OSo+UePfTrF+O++IkLumka4ocuTK7IP8gsa29xUQlkEMQKPH6laAcb2q1S68+Lg==
Thanks!
My next question is, how to construct more constant functions? Where
can I get more info about it?
On 15 December 2016 at 09:27, Cyprien Mangin
<cyprien.mangin AT m4x.org>
wrote:
> You actually only need any constant function x = y -> x = y (see below), so
> your projection function will work too. nu is just the most simple constant
> function you can define from decidable equality.
> Section eqdep_cons.
> Variable A : Type.
> Variable nu : forall (x y : A), x = y -> x = y.
> Arguments nu [_ _] _.
> Variable nu_cons : forall x y (p q : x = y), nu p = nu q.
> Definition nu_inv {x y : A} (p : x = y) : x = y :=
> eq_ind _ (fun a => a = y) p _ (nu eq_refl).
> Lemma nu_left_inv : forall x y (p : x = y), nu_inv (nu p) = p.
> Proof.
> destruct p. unfold nu_inv. destruct (nu eq_refl).
> reflexivity.
> Qed.
> Lemma UIP : forall (x y : A) (p q : x = y), p = q.
> Proof.
> intros.
> replace p with (nu_inv (nu p)) by (apply nu_left_inv).
> replace q with (nu_inv (nu q)) by (apply nu_left_inv).
> f_equal. apply nu_cons.
> Qed.
> End eqdep_cons.
> On Thu, Dec 15, 2016 at 10:09 AM, ikdc
> <ikdc AT mit.edu>
> wrote:
>> On 12/15/2016 04:05 AM, Chunhui He wrote:
>>> Hi all,
>>> I'm reading the proof of UIP on decidable domains in the standard
>>> library of coq:
>>> source: theories/Logic/Eqdep_dec.v
>>> doc: https://coq.inria.fr/library/Coq.Logic.Eqdep_dec.html
>>> The proof "eq_proofs_unicity_on" uses some definitions like "nu" and
>>> "nu_inv".
>>> I think the proof is confusing, does anyone know the meaning of "nu"
>>> and "nu_inv"?
>>> I try to simplify the proof by inlining (see below).
>>> I find we can use a projection instead of "nu" and "nu_inv".
>>> maybe it seem cleaner than the original proof?
>>> Thanks!
>>> Chunhui
>>> Section eqdep_dec.
>>> Variable A : Type.
>>> Variable A_dec : forall (x y : A), x = y \/ x <> y.
>>> Definition or_proj {x' y : A} (oreq : x' = y \/ x' <> y)
>>> (x : A) (def : x = y) : x = y :=
>>> match oreq with
>>> | or_introl H =>
>>> match A_dec x' x with
>>> | or_introl e =>
>>> match e in _ = y' return y' = y with
>>> | eq_refl => H
>>> end
>>> | or_intror _ => def
>>> end
>>> | or_intror _ => def
>>> end.
>>> Lemma or_proj_eq : forall {x y : A} (u : x = y), or_proj (A_dec x y) x
>>> u = u.
>>> Proof.
>>> intros x y u.
>>> unfold or_proj.
>>> case u.
>>> case (A_dec x x) as [Heq | Hneq].
>>> { case Heq. apply eq_refl. }
>>> { exfalso; apply (Hneq eq_refl). }
>>> Qed.
>>> Theorem eq_proofs_unicity : forall {x y : A} (p1 p2 : x = y), p1 = p2.
>>> Proof.
>>> intros x y p1 p2.
>>> case (or_proj_eq p1).
>>> case (or_proj_eq p2).
>>> unfold or_proj.
>>> case (A_dec x y) as [Heq | Hneq].
>>> { case (A_dec x x) as [Heq' | Hneq'] .
>>> { apply eq_refl. }
>>> { exfalso; apply (Hneq' eq_refl). } }
>>> { exfalso; apply (Hneq p1). }
>>> Qed.
>>> End eqdep_dec.
>> The idea is that nu is a sort of "normalization" function which takes all
>> equalities between x and y and maps them all to the same canonical equality
>> between x and y. This is the intuition behind nu_constant.
