coq-club - Re: [Coq-Club] Avoiding unnecessary universe variables when rewriting in Type
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Avoiding unnecessary universe variables when rewriting in Type
  • Date: Thu, 19 Jan 2017 06:57:35 +0000
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f182.google.com
  • Ironport-phdr: 9a23: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
You may be interested in https://coq.inria.fr/bugs/show_bug.cgi?id=5200https://coq.inria.fr/bugs/show_bug.cgi?id=4870https://coq.inria.fr/bugs/show_bug.cgi?id=4868.
You can reduce the number of used universes by doing some hackery like this:
Global Instance reflexive_proper_proxy
  : forall (A : Type)
           (R : crelation A),
    Reflexive R ->
    forall x : A,
      ProperProxy R x
  := fun (A : Type)
         (R : crelation A)
         (H : Reflexive R)
         (x : A) => (fun X : R x x => X) (H x).
Hint Extern 0 (ProperProxy ?R ?x)
=> unfold ProperProxy;
     let v := (eval unfold reflexivity in (@reflexivity _ R _ x)) in
     exact v
     : typeclass_instances.
Instance trans_co_eq_inv_arrow_morphism
  : forall (A : Type) (R : crelation A),
    Transitive R -> Proper (R ==> eq ==> flip arrow) R.
Proof. compute; intros; subst; eauto with nocore. Defined.
Hint Extern 0 (Proper ?P ?R)
=> let val := constr:(@trans_co_eq_inv_arrow_morphism _ R _ : Proper P R) in
   let val := (eval cbv [trans_co_eq_inv_arrow_morphism] in val) in
   let val := uconstr:(val) in
   exact val : typeclass_instances.
Then the body is:
test1@{Top.2685 Top.2753 Top.2754 Top.2760 Top.2788 Top.2854 Top.2860
Top.2905} =
fun (a b a' b' : U) (X : a == a') (X0 : b == b') =>
(fun lemma : a == a' =>
 (fun (x y : U) (X1 : x == y) (x0 y0 : U) (H : x0 = y0) (X2 : y == y0) =>
  eq_rect_r (fun x1 : U => x == x1)
    (Equivalence_Transitive@{I P} x y y0 X1 X2) H)
   (a * b) (a' * b)
   (star_Proper a a' lemma b b (Equivalence_Reflexive@{I P} b))
   (a' * b') (a' * b') (eq_Reflexive@{I Top.2788} (a' * b'))) X
  ((fun lemma : b == b' =>
      (a' * b) (a' * b')
      (Reflexive_partial_app_morphism@{I I I IP P IP} star_Proper
         (Equivalence_Reflexive@{I P} a') b b' lemma)
      (a' * b') (a' * b') (eq_Reflexive@{I Top.2905} (a' * b'))) X0
     (reflexivity@{I P} (a' * b')))
     : goal
(* Top.2685 Top.2753 Top.2754 Top.2760 Top.2788 Top.2854 Top.2860 Top.2905 |=
   P < Top.2685
   I <= IP
   I <= Top.2753
   I <= Top.2754
   I <= Top.2854
   I <= Coq.Init.Logic.8
   I <= Coq.Init.Logic.13
   P <= IP
   P <= Top.2754
   P <= Top.2854
   P <= Coq.Init.Logic.14
   Top.2685 <= Top.2753
   Top.2760 <= Top.2754
   Top.2860 <= Top.2854
Note how only two universes are mentioned.  Hopefully a better minimization algorithm would fix this.
As a work-around, you can do something like this:
Theorem test1' : goal.
Proof.
unfold goal. intros.
rewrite X, X0. reflexivity.
Defined.
(* for the one with my modifications: *)
Definition test1@{a} := Eval hnf in test1'@{a a a a Set a a Set}. (* feel free to replace [a] with [I] or [IP] if you're okay with the constraint [P < I] or [P < IP], respectively *)
(* for your version: *)
Definition test1@{a} := Eval hnf in test1'@{a a a a a a}. (* feel free to replace [a] with [I] or [IP] if you're okay with the constraint [P < I] or [P < IP], respectively *)
By carefully managing your universes at key points, you can avoid universe blow-up without introducing too much pain.
On Wed, Jan 18, 2017 at 9:53 PM Ben Sherman <sherman AT csail.mit.edu> wrote:
Hi all,
Coq 8.5 allows rewriting with Type-valued relations. This is useful, but I've found that using rewriting in Type to define a term often adds many unnecessary universe variables and constraints. If I'm not careful, these add up and soon enough a definition in my library has thousands of universe variables. Does anyone have ideas on how to avoid this, other than avoiding using rewriting in Type altogether? What follows is a short code example illustrating how unnecessary universe variables are added.
Thanks,
Ben
Set Universe Polymorphism.
Require Coq.Setoids.Setoid.
Require Import CRelationClasses CMorphisms.
Section Test.
Universes I P IP.
Variable U : Type@{I}.
Variable eqU : U -> U -> Type@{P}.
Variable star : U -> U -> U.
Local Infix "==" := eqU (at level 70, no associativity).
Local Infix "*" := star (at level 40, left associativity).
Axiom eqU_Equivalence : Equivalence eqU.
Axiom star_proper : forall (x x' y y' : U), x == x' -> y == y'
  -> x * y == x' * y'.
Instance star_Proper@{} : Proper@{I IP}
  (respectful@{I P I IP I IP} eqU (eqU ==> eqU)) star.
Proof.
repeat intro. apply star_proper; assumption.
Qed.
Set Printing Universes.
Definition goal@{} := forall a b a' b',
  a == a' -> b == b' -> a * b == a' * b'.
Theorem test1 : goal.
Proof.
Qed.
Print test1.
(* 9 extraneous universe variables, and 26 constraints. *)
Theorem test2@{} : goal.
Proof.
Qed.
Print test2.
(* No extraneous universe variables or constraints.*)
End Test.
