- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Setting Coq options for all files in a project
- Date: Tue, 7 Feb 2017 19:00:14 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT hera.mpi-klsb.mpg.de
- Ironport-phdr: 9a23:ks5fXBL6344ueYPE2NmcpTZWNBhigK39O0sv0rFitYgXIvjxwZ3uMQTl6Ol3ixeRBMOAuq4C27Kd4vmoGTRZp83e4DZaKN0EfiRGoPtVtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdazDIKD5yoGd3uyI8IPfP00I2WL8MvtOK0C9qhyUvc0Li6NjLLwww13HuChmYeNTkFlhIVzbvQv66Y/k/oNl/AxVo/Nk7NFbF6LgcPJrHvRjED06PjVtt4XQvh7ZQF7SvnY=
Hi,
all the "Load"-based approaches have one problem in common: it seems
impossible to "Load" a file from an installed library. So let's say
iris has a file "iris_options.v" ("Load" does not support giving paths
like "iris.options", so we have to do silly things like use globally
unique filenames). All Iris files do "Load iris_options."
Now we have something else using Iris, and it also wants to use the
same options. However, doing "Load iris_options." now fails because
"make install" totally did not install the "iris_options.v" file; just
"iris_options.vo" was installed.
On 03.02.2017 16:26, Anton Trunov wrote:
> Another version I can think of is to create 2 files:
> `SetOptions.v` and `UnsetOptions.v`.
> There are at least two disadvantages to this approach:
> - we need to remember to unset the options;
> - the user needs to set their options _after_ `Require Import lib`.
Plus, we need to know the default setting and keep our file up-to-date
with that. I don't think we'd want to go with this.
Kind regards,
Ralf
> best regards,
> Anton
>> On 3 Feb 2017, at 17:44, Ralf Jung
>> <jung AT mpi-sws.org>
>> wrote:
>> Hi,
>>> FWIW, `Load options.` would work for this minimalistic example.
>>> I'm not so sure if it's useful in your setting.
>> That's an interesting vernacular!
>> However, it doesn't seem to be intended for libraries. In particular, I
>> cannot say "Load iris.options.", I can only say "Load options." The
>> documentation says this is loaded from "the loadpath"; it seems not to
>> have been updated since -Q was added. But tests shows that the logical
>> path a physical directory is mapped to seems to be irrelevant for "Load".
>> The lack of qualification also means that even though we put everything
>> into an "iris" module, we have to call this file "iris_options" or so,
>> to make it globally unique...
>> Kind regards,
>> Ralf
>>> -Anton
>>>> On 3 Feb 2017, at 14:51, Ralf Jung
>>>> wrote:
>>>> Hi all,
>>>> there are some Coq options ("Set ...") that we want to set in a
>>>> particular way for all files in our library, but do not want to force on
>>>> our users. For example
>>>> Set Default Proof Using "Type".
>>>> Right now, we have that line at the top of every file, but that clearly
>>>> doesn't scale.
>>>> We got the advice to instead create a file, e.g. "options.v", put the
>>>> settings in there, and import that file everywhere. However, that does
>>>> not seem to work, as the following testcase shows:
>>>> $ cat options.v
>>>> Set Implicit Arguments.
>>>> $ cat test.v
>>>> Require Import options.
>>>> (* Set Implicit Arguments. *)
>>>> Definition id (A : Type) (a : A) := a.
>>>> Even though the option is set in "options.v", it is not in effect in
>>>> "test.v". I can of course change options.v to use "Global Set", but
>>>> then the option will leak to everything that even imports test.v, i.e.,
>>>> to every user of our library -- which we specifically tried to avoid.
>>>> Using "Require Import" or "Require" in test.v also does not seem to make
>>>> any difference.
>>>> Is there any way in Coq to set options in every file of a library
>>>> *without* imposing these options on the user, and without repeating the
>>>> option in every single file?
>>>> Kind regards,
>>>> Ralf
- [Coq-Club] Setting Coq options for all files in a project, Ralf Jung, 02/03/2017
- Re: [Coq-Club] Setting Coq options for all files in a project, Anton Trunov, 02/03/2017
- Re: [Coq-Club] Setting Coq options for all files in a project, Ralf Jung, 02/03/2017
- Re: [Coq-Club] Setting Coq options for all files in a project, Matthieu Sozeau, 02/03/2017
- Re: [Coq-Club] Setting Coq options for all files in a project, Ralf Jung, 02/07/2017
- Re: [Coq-Club] Setting Coq options for all files in a project, Pierre-Marie Pédrot, 02/07/2017
