- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Setting Coq options for all files in a project
- Date: Tue, 7 Feb 2017 20:28:08 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT hera.mpi-klsb.mpg.de
- Ironport-phdr: 9a23:U+QQkhS6RlTcpK5JGI/GxqQuwtpsv+yvbD5Q0YIujvd0So/mwa67bBGN2/xhgRfzUJnB7Loc0qyN4vymCTRLuM7f+DBaKdoXCE9D0Z1X1yUbQ+e7SmTDZMbwaCI7GMkQHHRExFqcdXZvJcDlelfJqWez5zNBUj/2NA5yO/inUtWK15f/4dqc0NiWSQxEvjGjbe86bEju7FaZis5Diox7b6011xHho31Seu0Qy3k7C0iUmkPG78O+tLx+9SsY7/A88cFoVL37Or8nVvpfFjtwYDN939HiqRSWFVjH3XAbSGhDz0JF
Hi,
> On 07/02/2017 19:02, Ralf Jung wrote:
>> I was told once that just doing "Set ...." would set options in a way
>> that they would apply through one, but *not* two levels of "Import" (and
>> an arbitrary number of "Export"), but that doesn't actually seem to be
>> the case.
> Being the one who told you that, I feel guilty. Still, this seems like a
> bug to me, and I was pretty sure that this was the expected behaviour.
> I'll have a look when I have spare time.
Great, thanks.
No reason to feel guilty though, Coq is a nasty beast, seems like it can
even confuse its developers. ;)
> In the meanwhile, ****PLEASE DO NOT USE LOAD****. Pardon the
> capitalizing, but that's important matter here. This command is a rather
> horrendous hack that SHOULD NOT appear in proper development files. It
> is borderline to use it in interactive proofs, and it should not be used
> anywhere else. I even think it is more or less bound to be removed at a
> future stage.
Horrendous hacks seem to be what we use frequently. ;)
It seems though then as if we don't really have any option right now for
setting options just inside a library. Probably we will end up not
doing anything then, just sticking with what we got -- and continue to
try and remember to set "Default Proof Using" in every single file.
Kind regards,
Ralf
- [Coq-Club] Setting Coq options for all files in a project, Ralf Jung, 02/03/2017
- Re: [Coq-Club] Setting Coq options for all files in a project, Anton Trunov, 02/03/2017
- Re: [Coq-Club] Setting Coq options for all files in a project, Ralf Jung, 02/03/2017
- Re: [Coq-Club] Setting Coq options for all files in a project, Matthieu Sozeau, 02/03/2017
- Re: [Coq-Club] Setting Coq options for all files in a project, Ralf Jung, 02/07/2017
- Re: [Coq-Club] Setting Coq options for all files in a project, Pierre-Marie Pédrot, 02/07/2017
