coq-club - Re: [Coq-Club] injectivity of inductive type implies False
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] injectivity of inductive type implies False
  • Date: Wed, 1 Mar 2017 12:40:43 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f171.google.com
  • Ironport-phdr: 9a23:o0I41xJAPnk0l1ESr9mcpTZWNBhigK39O0sv0rFitYgXI/jxwZ3uMQTl6Ol3ixeRBMOAuq8C0LKd6vi5ESxYuNDa7yBEKMQNHzY+yuwo3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9ScbuiJG80Pn38JnOaU0cjz2kJLh2MR+erAPLt8BQj5E0eYgrzR6ci3FIev9WyGAgDFSamRq0ss66/J948ylT/fsn/shMF6T7Y6sQQrlRDTBgOGcwsp64/SLfRBeCsyNPGl4dlQBFVlDI
Inductive array (A:Type):nat->Type:=
|nil : array A 0
|cons : forall n:nat, A -> array A n -> array A (S n).
array m A=array n A -> m=n?
(Assuming you meant array A m instead of array m A)
I think that using something like the univalence axiom, you can prove:
array False 2 = array False 4
Then it would be bad to conclude 2=4.
-- Abhishek
http://www.cs.cornell.edu/~aa755/
