coq-club - Re: [Coq-Club] Second order logic library?
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Second order logic library?
  • Date: Thu, 23 Mar 2017 01:41:52 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-wr0-f176.google.com
  • Ironport-phdr: 9a23:L8OCphUS7Zm6mSBlTD2Qf0Q6g2fV8LGtZVwlr6E/grcLSJyIuqrYZhWFt8tkgFKBZ4jH8fUM07OQ6PG9HzNaqsra+DBaKdoXCE9D0Z1X1yUbQ+e7SmTDZMbwaCI7GMkQHHRExFqcdXZvJcDlelfJqWez5zNBUj/2NA5yO/inUtWK15f//6mI9pbSewRFgiamKfM3dU3u7FaZis5Dqox7Yo011xGB9nBPYqFdwX5iDVOVhRf1oMmqqs1N6SNV7sog+tRaXO3ReLkiUb1VEXxyK2E4/tfm8xLEUBGT53YBemoTmxtMRQPC6UepDd/KriLmu78li2GhNsrsQOVxAGz64g==
Hi,
Adam means that Coq itself understand second order logic at its heart.
You don't need to develop a library for that, you can just formalize
your problems directly,
For example: "forall (R:nat ->nat -> Prop), forall n, R n n \/ R n 0"
is a formula that coq understands perfectly (although it is not
provable).
The typical situation where you need to formalize formulas by a
concrete type is if you want to prove meta-properties about second
order formulas themselves (like correctness or completeness of some
proof system).
Maybe a more precise description of the problems you want to formalise
and the kind of theorems you would like to prove about them would
help.
Best regards,
Pierre
2017-03-23 1:21 GMT+01:00 Caitlin McGregor
<caitlin.mcgregor AT anu.edu.au>:
> Thanks for your response. (Apologies for the first order part of the
> question - that was silly!)
> The context is that if I wish to formalise some problem that involves second
> order formulas, I would like a library that defines such a type and proves a
> collection of lemmas that are in some sense "obvious" to the mathematician
> and require no explanation.
> One idea is to define the type myself and then define functions between my
> own second order formulas and some set theoretic notions, and then prove
> inside set theory. But I was wondering if there was a library that was
> explicitly working with second order formulas.
> Please bear with any misunderstandings that I have. Any help that you could
> provide would be greatly appreciated.
> Kind regards,
> Caitlin
> ________________________________
> From:
> coq-club-request AT inria.fr
> <coq-club-request AT inria.fr>
> on behalf of
> Adam Chlipala
> <adamc AT csail.mit.edu>
> Sent: Thursday, 23 March 2017 11:06:44 AM
> To:
> What exactly would be in such a library, considering that, in a reasonable
> sense, second-order logic is a subset of Coq's full logic?
> On 03/22/2017 08:03 PM, Caitlin McGregor wrote:
> Hi all,
> I am looking for a second order logic library in Coq, or even a first order
> library. Does anyone know if these are available?
> Thanks in advance,
> Caitlin
