coq-club - Re: [Coq-Club] Second order logic library?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Second order logic library?
  • Date: Thu, 23 Mar 2017 13:32:11 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=asyabergal AT gmail.com; spf=Pass smtp.mailfrom=asyabergal AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f170.google.com
  • Ironport-phdr: 9a23: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
It seems like you're looking for is known as a deep embedding of second-order logic in Coq. People are describing to you that you can use a shallow embedding inside of Coq instead, which is true but not useful to you (http://cstheory.stackexchange.com/questions/1370/shallow-versus-deep-embeddings).
I myself needed a deep-embedding of First Order logic for a former of project of mine, and failed to find an reasonable existing one. I've attached the very minimal formalization that I produced in case it's useful to you.
Good luck!
On Wed, Mar 22, 2017 at 10:21 PM, Caitlin McGregor <caitlin.mcgregor AT anu.edu.au> wrote:
Hi,
Ah I see where my lack of clarity is. Indeed, I do realise that Coq understands second order logic at its heart. I am working on proving meta-properties, in particular in correspondence theory. This shows certain correspondences between modal logic and first order logic, and in my case I go via second order logic.
Perhaps examples will help. Here is what I have already for the fragment of second order logic that I am working with:
(* Countably many unary predicates *)
Inductive predicate : Type :=
  Pred (n:nat) : predicate.
(* Countable many first order variables *)
Inductive FOvariable : Type :=
  Var (n:nat) : FOvariable.
(* The fragment of second order logic that I'm working with *)
Inductive SecOrder :=
    predSO : predicate -> FOvariable -> SecOrder
  | eqFO : FOvariable -> FOvariable -> SecOrder
  | allFO : FOvariable -> SecOrder -> SecOrder
  | exFO : FOvariable -> SecOrder -> SecOrder
  | negSO : SecOrder -> SecOrder
  | conjSO : SecOrder -> SecOrder -> SecOrder
  | disjSO : SecOrder -> SecOrder -> SecOrder
  | implSO : SecOrder -> SecOrder -> SecOrder
  | allSO : predicate -> SecOrder -> SecOrder
  | exSO : predicate -> SecOrder -> SecOrder.
Then, I define a satisfaction relation, SOturnst:
(* Iv = interpretation of FOvariables;
   Ip = interpretation of unary predicates *)
Fixpoint SOturnst (D:Set) (Iv: FOvariable -> D) (Ip: predicate -> D -> Prop)  (alpha:SecOrder) : Prop :=
  match alpha with
    predSO (Pred n) (Var m) => (Ip (Pred n) (Iv (Var m)))
  | eqFO (Var n) (Var m) => (Iv (Var n)) = (Iv (Var m))
  | allFO (Var n) beta => forall d:D, SOturnst D (altered_Iv D Iv d (Var n)) Ip Ir beta
  | exFO (Var n) beta => (exists d:D, SOturnst D (altered_Iv D Iv d (Var n)) Ip Ir beta)
  | negSO beta => ~ SOturnst D Iv Ip Ir beta
  | conjSO beta_1 beta_2 => (SOturnst D Iv Ip Ir beta_1) /\ (SOturnst D Iv Ip Ir beta_2)
  | disjSO beta_1 beta_2 => (SOturnst D Iv Ip Ir beta_1) \/ (SOturnst D Iv Ip Ir beta_2)
  | implSO beta_1 beta_2 => (SOturnst D Iv Ip Ir beta_1) -> (SOturnst D Iv Ip Ir beta_2)
  | allSO (Pred n) beta => forall (pred_asgmt: D -> Prop),
                               SOturnst D Iv (altered_Ip D Ip pred_asgmt (Pred n)) Ir beta
  | exSO (Pred n) beta => (exists (pred_asgmt: D -> Prop),
                              (SOturnst D Iv (altered_Ip D Ip pred_asgmt (Pred n)) Ir beta))
  end.
(This definition uses two functions that I didn't give definitions to, but it's not important for our purposes.)
Then a small example of what I might want to be able to use might be:
Lemma lem : forall (D : Set) (Iv : FOvariable -> D) (Ip : predicate -> D -> Prop) (alpha : SecOrder) (P : predicate),
SOturnst D Iv Ip (allSO P (allSO P alpha)) ->
SOturnst D Iv Ip (allSO P alpha).
But ideally I don't want to have to prove things like this, if there so happens to be a library that does it for me. It's okay if there isn't; was just wondering if someone had already done something like this.
Is there any other information that would help you answer the questions? Thanks for your help.
Kind regards,
Caitlin
From: coq-club-request AT inria.fr <coq-club-request AT inria.fr> on behalf of Pierre Courtieu <pierre.courtieu AT gmail.com>
Sent: Thursday, 23 March 2017 11:41:52 AM
To: Coq Club
Hi,
Adam means that Coq itself understand second order logic at its heart.
You don't need to develop a library for that, you can just formalize
your problems directly,
For example: "forall (R:nat ->nat -> Prop), forall n, R n n \/ R n 0"
is a formula that coq understands perfectly (although it is not
provable).
The typical situation where you need to formalize formulas by a
concrete type is if you want to prove meta-properties about second
order formulas themselves (like correctness or completeness of some
proof system).
Maybe a more precise description of the problems you want to formalise
and the kind of theorems you would like to prove about them would
help.
Best regards,
Pierre
2017-03-23 1:21 GMT+01:00 Caitlin McGregor <caitlin.mcgregor AT anu.edu.au>:
> Thanks for your response. (Apologies for the first order part of the
> question - that was silly!)
> The context is that if I wish to formalise some problem that involves second
> order formulas, I would like a library that defines such a type and proves a
> collection of lemmas that are in some sense "obvious" to the mathematician
> and require no explanation.
> One idea is to define the type myself and then define functions between my
> own second order formulas and some set theoretic notions, and then prove
> inside set theory. But I was wondering if there was a library that was
> explicitly working with second order formulas.
> Please bear with any misunderstandings that I have. Any help that you could
> provide would be greatly appreciated.
> Kind regards,
> Caitlin
> ________________________________
> Adam Chlipala <adamc AT csail.mit.edu>
> Sent: Thursday, 23 March 2017 11:06:44 AM
> What exactly would be in such a library, considering that, in a reasonable
> sense, second-order logic is a subset of Coq's full logic?
> On 03/22/2017 08:03 PM, Caitlin McGregor wrote:
> Hi all,
> I am looking for a second order logic library in Coq, or even a first order
> library. Does anyone know if these are available?
> Thanks in advance,
> Caitlin
Set Implicit Arguments.
Unset Strict Implicit.
Require Import Coq.Lists.List.
Import ListNotations.
Section Hlist.
  (* Heterogenous list type. *)
  Inductive hlist A (f : A -> Type) : list A -> Type :=
  | hnil : hlist f []
  | hcons : forall x l, f x -> hlist f l -> hlist f (x :: l).
  Definition hmap A (f : A -> Type) B (g : B -> Type)
             (F : A -> B) (F' : forall a, f a -> g (F a))
             (l : list A) (h : hlist f l) : hlist g (map F l).
    induction h; constructor; auto.
  Defined.
  Definition hmap' A (f : A -> Type) (g : A -> Type)
             (F' : forall a, f a -> g a)
             (l : list A) (h : hlist f l) : hlist g l.
    replace l with (map id l).
    apply hmap with (f := f); assumption.
    clear f g F' h.
    induction l as [| x xs IHl]; [| simpl; rewrite IHl]; reflexivity.
  Defined.
End Hlist.
Notation " h[] " := (hnil _).
Infix "h::" := hcons (at level 60, right associativity).
Section FirstOrder.
  Context (sort : Type)
          (func : list sort -> sort -> Type)
          (predicate : list sort -> Type).
  Inductive term : sort -> Type :=
    App : forall {dom cod},
            (func dom cod) -> hlist term dom -> term cod.
  Definition term_terms_rect
             (P : forall s, term s -> Type)
             (Q : forall ss, hlist term ss -> Type)
             (c_app : forall {dom} {cod} (f : func dom cod)
                             (ts : hlist term dom),
                        Q dom ts -> P cod (App f ts))
             (c_nil : Q [] h[])
             (c_cons : forall {s} (t : term s) {ss} (ts : hlist term ss),
                         P s t -> Q ss ts -> Q (s :: ss) (t h:: ts)) :
    forall {s} (t : term s), P s t :=
    fix F {s} (t : term s) : P s t :=
    match t with
      | App f ts =>
        c_app f ts
              ((fix G {ss} (ts : hlist term ss) : Q ss ts :=
                  match ts with
                    | h[] => c_nil
                    | t h:: ts => c_cons t ts (F t) (G ts)
                  end) _ ts)
    end.
  Record model :=
    Model
      {domain :> sort -> Type;
       interp_func : forall dom cod,
                       func dom cod ->
                       hlist domain dom ->
                       domain cod;
       interp_predicate : forall dom,
                            predicate dom ->
                            hlist domain dom -> Prop}.
  Definition interp_term (m : model) s (t : term s) : m s.
    apply term_terms_rect with
    (P := (fun s t => m s))
      (Q := fun ss ts => hlist m ss)
      (t := t); clear s t.
    - (* app *)
      intros dom cod f x IHts.
      apply (interp_func f); assumption.
    - (* nil *)
      constructor.
    - (* cons *)
      constructor; assumption.
  Defined.
  Definition interp_terms (m : model) ss (ts : hlist term ss)
  : hlist m ss :=
    hmap' (interp_term _) ts.
  Section formulas.
    Variable d : sort -> Type.
    Inductive formula : Type :=
    | Predicate : forall ss, predicate ss -> hlist term ss -> formula
    | And : formula -> formula -> formula
    | Or : formula -> formula -> formula
    | Not : formula -> formula
    | Forall : forall s, (d s -> formula) -> formula
    | Exists : forall s, (d s -> formula) -> formula
    | FTrue : formula
    | FFalse : formula.
  End formulas.
  Arguments FTrue {d}.
  Arguments FFalse {d}.
  Definition Formula := forall d : sort -> Type, formula d.
  Fixpoint interp_formula (m : model) (f : formula m) : Prop :=
    match f with
      | Predicate _ p ts => interp_predicate p (interp_terms m ts)
      | And f1 f2 => interp_formula f1 /\ interp_formula f2
      | Or f1 f2 => interp_formula f1 \/ interp_formula f2
      | Not f => ~interp_formula f
      | @Forall _ s f => forall x : m s, interp_formula (f x)
      | @Exists _ s f => exists x : m s, interp_formula (f x)
      | FTrue => True
      | FFalse => False
    end.
  Definition interp_Formula (m : model) (f : Formula) :=
    interp_formula (f m).
End FirstOrder.
