- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Opaque module typing with exposing function defs
- Date: Thu, 27 Apr 2017 14:49:53 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f177.google.com
- Ironport-phdr: 9a23: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
Note that truly hiding private definitions which are used to define public transparent ones would break subject reduction, and is impossible; it would mean that you could unfold a well-typed identifier and get a term which is invalid.
On Thu, Apr 27, 2017, 10:46 AM Jason Gross <jasongross9 AT gmail.com> wrote:
Does this do what you want?
Module Type Addition.
Parameter t : Type.
Parameter add : t -> t -> t.
End Addition.Module MAddition <: Addition.
Definition t := nat.
Definition add x y := x + y. (* I want this to be available *)Local Definition priv_id (x : t) := x. (* This must be hidden *)
End MAddition.On Thu, Apr 27, 2017, 7:45 AM Julia Belyakova <julbinb AT gmail.com> wrote:Hello Ralf,I use an aux private function to implement a public one, so this solution does not work in this case.--Hi,
On 27.04.2017 03:03, Julia Belyakova wrote:
> Thank you for reply!
> Are there other ways to hide some parts of a module except for opaque
> typing? I am primarily interested in hiding auxiliary lemmas.
Doesn't the following, proposed in the previous mail by Istvan, do
exactly that?
> Module MAddition : Addition
> with Definition t := nat
> with Definition add := fun x y => x + y.
> End MAddition.
Of course, the annoying part is that addition is defined twice. This is
something I have also encountered when I do hiding via modules: Many of
the things that *are* exported have to be duplicated.
; Ralf
> It seems to me strange though that one cannot actually _use_ functions
> from the opaque-typed module.
> Kind regards,
> Julia
> ср, 26 апр. 2017 г., 17:10 ikdc <ikdc AT mit.edu <mailto:ikdc AT mit.edu>>:
> On 04/26/2017 04:57 PM, Julia Belyakova wrote:
> > Dear Coq users,
> > I guess it's a stupid question, but...
> > I want to define a module with certain parts being hidden. For this I
> > define a module type and then use opaque typing for the module.
> And the
> > problem is that now I cannot compute functions of the module, their
> > definitions are not accessible.
> > Please, find a simple example below.
> > Parameter t : Type.
> > End Addition.
> > Module MAddition : Addition with Definition t := nat.
> > End MAddition.
> > (* priv_id is not available as desired *)
> > (* Compute (MAddition.priv_id 4). *)
> > (* add is available, but the call does not reduce to 7 *)
> > Compute (MAddition.add 3 4).
> If I understand correctly, I don't think you can do this. The fact that
> the module type is opaque means that any program which uses a module
> with that type must behave the same way; in particular it may not unfold
> the definitions hidden by the module type. You could of course do this:
> End MAddition.
> But if you want to be able to compute through [add], then perhaps the
> module type "Addition" isn't actually the interface you want to be using
> in the first place.
> I don't know very much about the module system, so someone please
> correct me if this is wrong.
> Istvan Chung
- [Coq-Club] Opaque module typing with exposing function defs, Julia Belyakova, 04/26/2017
- Re: [Coq-Club] Opaque module typing with exposing function defs, ikdc, 04/26/2017
- Re: [Coq-Club] Opaque module typing with exposing function defs, Julia Belyakova, 04/27/2017
- Re: [Coq-Club] Opaque module typing with exposing function defs, Ralf Jung, 04/27/2017
- Re: [Coq-Club] Opaque module typing with exposing function defs, Jason Gross, 04/27/2017
- Re: [Coq-Club] Opaque module typing with exposing function defs, Gaetan Gilbert, 04/27/2017
- Re: [Coq-Club] Opaque module typing with exposing function defs, Pierre Courtieu, 04/27/2017
