- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Opaque module typing with exposing function defs
- Date: Thu, 27 Apr 2017 14:53:00 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f174.google.com
- Ironport-phdr: 9a23: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
Another possibility is to use sections and [Let], so your private definitions are inlined in your public ones:
Module Type Addition.
Parameter t : Type.
Parameter add : t -> t -> t.
End Addition.
Module MAddition <: Addition.
Section maddition.
Definition t := nat.
Definition add x y := x + y. (* I want this to be available *)
Let priv_id (x : t) := x. (* This must be hidden *)
End maddition.
End MAddition.
Note that truly hiding private definitions which are used to define public transparent ones would break subject reduction, and is impossible; it would mean that you could unfold a well-typed identifier and get a term which is invalid.
On Thu, Apr 27, 2017, 10:46 AM Jason Gross <jasongross9 AT gmail.com> wrote:Does this do what you want?
Parameter t : Type.
End Addition.Module MAddition <: Addition.
Definition add x y := x + y. (* I want this to be available *)Local Definition priv_id (x : t) := x. (* This must be hidden *)
End MAddition.On Thu, Apr 27, 2017, 7:45 AM Julia Belyakova <julbinb AT gmail.com> wrote:Hello Ralf,I use an aux private function to implement a public one, so this solution does not work in this case.--Hi,
On 27.04.2017 03:03, Julia Belyakova wrote:
> Thank you for reply!
> Are there other ways to hide some parts of a module except for opaque
> typing? I am primarily interested in hiding auxiliary lemmas.
Doesn't the following, proposed in the previous mail by Istvan, do
exactly that?
> Module MAddition : Addition
> with Definition t := nat
> with Definition add := fun x y => x + y.
> End MAddition.
Of course, the annoying part is that addition is defined twice. This is
something I have also encountered when I do hiding via modules: Many of
the things that *are* exported have to be duplicated.
; Ralf
> It seems to me strange though that one cannot actually _use_ functions
> from the opaque-typed module.
> Kind regards,
> Julia
> ср, 26 апр. 2017 г., 17:10 ikdc <ikdc AT mit.edu <mailto:ikdc AT mit.edu>>:
> On 04/26/2017 04:57 PM, Julia Belyakova wrote:
> > Dear Coq users,
> > I guess it's a stupid question, but...
> > I want to define a module with certain parts being hidden. For this I
> > define a module type and then use opaque typing for the module.
> And the
> > problem is that now I cannot compute functions of the module, their
> > definitions are not accessible.
> > Please, find a simple example below.
> > Parameter t : Type.
> > End Addition.
> > Module MAddition : Addition with Definition t := nat.
> > End MAddition.
> > (* priv_id is not available as desired *)
> > (* Compute (MAddition.priv_id 4). *)
> > (* add is available, but the call does not reduce to 7 *)
> > Compute (MAddition.add 3 4).
> If I understand correctly, I don't think you can do this. The fact that
> the module type is opaque means that any program which uses a module
> with that type must behave the same way; in particular it may not unfold
> the definitions hidden by the module type. You could of course do this:
> End MAddition.
> But if you want to be able to compute through [add], then perhaps the
> module type "Addition" isn't actually the interface you want to be using
> in the first place.
> I don't know very much about the module system, so someone please
> correct me if this is wrong.
> Istvan Chung
- [Coq-Club] Opaque module typing with exposing function defs, Julia Belyakova, 04/26/2017
- Re: [Coq-Club] Opaque module typing with exposing function defs, ikdc, 04/26/2017
- Re: [Coq-Club] Opaque module typing with exposing function defs, Julia Belyakova, 04/27/2017
- Re: [Coq-Club] Opaque module typing with exposing function defs, Ralf Jung, 04/27/2017
- Re: [Coq-Club] Opaque module typing with exposing function defs, Jason Gross, 04/27/2017
- Re: [Coq-Club] Opaque module typing with exposing function defs, Gaetan Gilbert, 04/27/2017
- Re: [Coq-Club] Opaque module typing with exposing function defs, Pierre Courtieu, 04/27/2017
