coq-club - [Coq-Club] Problems with dependent pattern matching
  • From: Christian Kjær Larsen <christianden AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Problems with dependent pattern matching
  • Date: Tue, 2 May 2017 14:45:58 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=christianden AT gmail.com; spf=Pass smtp.mailfrom=christianden AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f52.google.com
  • Ironport-phdr: 9a23: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
Hi,
I'm currently writing my bachelors thesis, and I'm hitting some problems with pattern matching on dependent
types, and I was wondering if you guys could help. It seems a bit difficult to work with in Coq.
I'm trying to formalise a small array language using intrinsically typed
syntax, de bruijn indices for binders and Adam Chlipalas heterogeneous list implementation from his book.
The idea is that I want to implement some fusion rules (like https://wiki.haskell.org/Fusion), and prove them correct using a semantics encoded in Coq.
The syntax is like this
Inductive exp G : ty -> Type :=
| evar : forall t, member t G -> exp G t
| etrue : exp G TBool
| efalse : exp G TBool
| econst : nat -> exp G TNat
| esucc : exp G TNat -> exp G TNat
| enil : forall t, exp G (TList t)
| econs : forall t, exp G t -> exp G (TList t) -> exp G (TList t)
| emap : forall t1 t2, exp (t1 :: G) t2 -> exp G (TList t1) -> exp G (TList t2)
| efilter : forall t1, exp (t1 :: G) TBool -> exp G (TList t1) -> exp G (TList t1).
And I have tried to define a fusion rule for (map f (map g) == map (f o g)) like this
Definition map_fusion t G (e : exp G t) :=
  match e in exp _ t return exp G t with
  | emap t2 t1 g em => match em in exp _ (TList t3) return exp G t with
                       | emap t3 t2 f eb => emap (compose f g) eb
                       | _ => e
                       end
  |  _ => e
end.
This does not work, because Coq does not know that the t2's are the
same. Do you have any tips for doing this style of dependent pattern
matching in Coq. I have tried to use the Program tactic, but I hit some
kind of bug. (https://coq.inria.fr/bugs/show_bug.cgi?id=5473).
I hope that my question makes sense, and that some of you will have the time to answer.
Cheers,
Student at the University of Copenhagen, Denmark.
