coq-club - Re: [Coq-Club] Problems with dependent pattern matching
  • From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Problems with dependent pattern matching
  • Date: Tue, 2 May 2017 11:48:21 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.boutillier AT pps.univ-paris-diderot.fr; spf=None smtp.mailfrom=SRS0=xg0K=4I=pps.univ-paris-diderot.fr=pierre.boutillier AT bounce.ens-lyon.org; spf=Pass smtp.helo=postmaster AT sonata.ens-lyon.org
  • Ironport-phdr: 9a23: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
Hi,
Just for fun :
Using Coq 8.6, if ty is an inductive defined as Inductive ty := TBool : ty |
TNat : ty | TList : ty -> ty.
--8<----
Definition map_fusion t G (e : exp G t) :=
match e in exp _ t return exp G t with
| emap _ t2 t1 g em => match em in exp _ (TList t2')
return exp (t2'::G) t1 -> exp G (TList t1) with
| emap _ t3 t2'' f eb => fun g' => emap _ _ _ (compose
_ _ _ _ g' f) eb
| em => fun _ => emap _ _ _ g em
end g
| e => e
end.
--8<----
works sadly only at 95% : Coq says : Error: Cannot infer an internal
placeholder of type "Type". Too bad because it could take whatever it wants !
Therefore you have to either do
--8<----
Definition map_fusion t G (e : exp G t) : exp G t.
Proof.
refine
(match e in exp _ t return exp G t with
_ _ _ _ g' f) eb
end g
| e => e
end).
exact hilbert_paradox.
exact fermat_last_thoerem.
Defined.
--8<-----
or
--8<-----
Definition map_fusion t G (e : exp G t) : exp G t :=
| emap _ t2 t1 g em => match em in exp _ foo
return match foo with
| TList t2' => exp (t2'::G) t1 -> exp G
(TList t1)
| _ => True end with
_ _ _ _ g' f) eb
| (enil _ _ | econs _ _ _ _ | efilter _ _ _ _) as em =>
| _ => I
end g
| e => e
end.
--8<-----
Pierre B.
> Le 2 mai 2017 à 08:45, Christian Kjær Larsen
> <christianden AT gmail.com>
> a écrit :
> Hi,
> I'm currently writing my bachelors thesis, and I'm hitting some problems
> with pattern matching on dependent
> types, and I was wondering if you guys could help. It seems a bit difficult
> to work with in Coq.
> I'm trying to formalise a small array language using intrinsically typed
> syntax, de bruijn indices for binders and Adam Chlipalas heterogeneous list
> implementation from his book.
> The idea is that I want to implement some fusion rules (like
> https://wiki.haskell.org/Fusion
> ), and prove them correct using a semantics encoded in Coq.
> The syntax is like this
> Inductive exp G : ty -> Type :=
> | evar : forall t, member t G -> exp G t
> | etrue : exp G TBool
> | efalse : exp G TBool
> | econst : nat -> exp G TNat
> | esucc : exp G TNat -> exp G TNat
> | enil : forall t, exp G (TList t)
> | econs : forall t, exp G t -> exp G (TList t) -> exp G (TList t)
> | emap : forall t1 t2, exp (t1 :: G) t2 -> exp G (TList t1) -> exp G (TList
> t2)
> | efilter : forall t1, exp (t1 :: G) TBool -> exp G (TList t1) -> exp G
> (TList t1).
> And I have tried to define a fusion rule for (map f (map g) == map (f o g))
> like this
> | emap t2 t1 g em => match em in exp _ (TList t3) return exp G t with
> | emap t3 t2 f eb => emap (compose f g) eb
> | _ => e
> end
> | _ => e
> end.
> This does not work, because Coq does not know that the t2's are the
> same. Do you have any tips for doing this style of dependent pattern
> matching in Coq. I have tried to use the Program tactic, but I hit some
> kind of bug. (
> https://coq.inria.fr/bugs/show_bug.cgi?id=5473
> I hope that my question makes sense, and that some of you will have the
> time to answer.
> Cheers,
> Student at the University of Copenhagen, Denmark.
