coq-club - Re: [Coq-Club] How to represent tabular data in Coq
  • To: coq-club AT inria.fr, Klaus Ostermann <klaus.ostermann AT uni-tuebingen.de>
  • Subject: Re: [Coq-Club] How to represent tabular data in Coq
  • Date: Tue, 9 May 2017 23:38:48 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sherman AT csail.mit.edu; spf=Pass smtp.mailfrom=sherman AT csail.mit.edu; spf=None smtp.helo=postmaster AT outgoing-stata.csail.mit.edu
  • Ironport-phdr: 9a23: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
If you're just looking to represent something like this (rather than implement it with some efficient data structure), you can basically do exactly what you wrote:
Inductive member {A} (x : A) : list A -> Type :=
  | here : forall xs, member x (x :: xs)
  | there : forall y xs, member x xs -> member x (y :: xs).
Infix "∈" := member (at level 30).
Record Table (R C : Type) (r : list R) (c : list C) A := MkTable
  { lookup : forall x y, x ∈ r -> y ∈ c -> A }.
(* Another version, which could be a bit easier in saving
   you from needing UIP unnecessarily *)
Inductive members {A} : list A -> Type :=
  | here' : forall x xs, members (x :: xs)
  | there' : forall x xs, members xs -> members (x :: xs).
Record Table' (R C : Type) (r : list R) (c : list C) A :=
  MkTable' { lookup' : members r -> members c -> A }.
The [member] inductive family is not in the Coq standard library, though it's a common thing to do. I can point you to various code defining such a family that could have lemmas you could use that you might find useful:
http://adam.chlipala.net/cpdt/html/DataStruct.html
https://github.com/coq-ext-lib/coq-ext-lib/blob/v8.5/theories/Data/Member.v
https://github.com/bmsherman/topology/blob/master/src/Types/List.v#L8-L10
(You might notice that [list unit] is isomorphic to [nat], and similarly [@members unit] is isomorphic to [Fin.t], and [Fin.t n -> A] is isomorphic to [Vector.t A n], which relates some of the definitions here to [Vector.t].)
From: Klaus Ostermann <klaus.ostermann AT uni-tuebingen.de>
Subject: [Coq-Club] How to represent tabular data in Coq
Date: May 8, 2017 at 11:14:52 AM EDT
I have data that one would write down on a piece of paper as a table
with row and column headers.
The type of the headers is not "nat", though (otherwise I could use
nested vectors).
Let's call them R and C for the type of row headers and column headers,
respectively.
The type of the table elements is A.
Let's say I have finite sets r and c of R's and C's, respectively. r and
c are the labels
of a particular table.
Such a table should feature a function to look up an entry in the table,
which should
have a type similar to this:
lookup: Table R C r c A -> x in r -> y in c -> A
where "x in r" means a label x that is in the label set r.
In particular, the lookup function should not return an "option A".
Is there something like this in a standard library? How would I go about
this?
As a starter, is there something that is to standard finite maps as
vectors are to lists?
That is, finite maps where the type system keeps track of the available
keys?
Klaus
