- To: coq-club AT inria.fr
- Cc: Klaus Ostermann <klaus.ostermann AT uni-tuebingen.de>
- Subject: Re: [Coq-Club] How to represent tabular data in Coq
- Date: Wed, 17 May 2017 16:44:22 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f174.google.com
- Ironport-phdr: 9a23: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
> So if there is more than one proof of [x = y], there will be more elements in [sigT (fun x => member x xs)] than [members xs]. Usually I've found that I prefer [members] to [member] for this reason.
Not so. Even if there are multiple proofs of [x = x], the type [sigT (fun y => x = y)] has only one element up to equality. Here's a proof that [sigT (fun x => member x xs)] has decidable equality, based on the encode-decode method of HoTT:
Require Import List.
Section with_type.
Context {A : Type}.
Inductive member (x : A) : list A -> Type :=
| here : forall y xs, x = y -> member x (y :: xs)
| there : forall y xs, member x xs -> member x (y :: xs).
Definition members ls := { x : A & member x ls }.
Fixpoint beq_hetero {ls ls'} {x0} (x : member x0 ls) {y0} (y : member y0 ls')
: bool
:= match x, y with
| here _ _ _ _, here _ _ _ _ => true
| here _ _ _ _, _ => false
| there _ _ _ m, there _ _ _ m' => @beq_hetero _ _ _ m _ m'
| there _ _ _ _, _ => false
end.
Definition beq {ls} (x y : members ls) : bool
:= @beq_hetero ls ls _ (projT2 x) _ (projT2 y).
Definition code ls (x y : members ls) := beq x y = true.
Fixpoint encode'_exploded ls x0 (x : member x0 ls)
: @beq_hetero ls ls _ x _ x = true
:= match x with
| here _ _ _ _ => eq_refl
| there _ _ _ m => @encode'_exploded _ _ m
end.
Definition encode {ls} {x y} (H : x = y :> members ls) : code ls x y
:= match H with
| eq_refl => encode'_exploded _ _ _
end.
Local Ltac do_member_small_inversion_on m :=
(* adjust the goal so that all things which depend on arguments of [member]
are reverted, and so that the arguments come first, followed by [m] *)
is_var m; move m at top;
lazymatch type of m with
| member _ (cons ?x ?xs)
=> is_var x; is_var xs;
revert dependent x; intros x m; move m at top;
revert dependent xs; revert x
| ?T => fail "wrong type" T
end;
let P := match goal with |- forall x xs y, @?P x xs y => P end in
let x := fresh "x" in
let xs := fresh "xs" in
intros x xs m;
refine match m in member _ ls
return match ls with
| nil => fun _ => False
| cons x xs => P x xs
end m
with
| here _ _ _ _ => _
| _ => _
end.
Import EqNotations.
Fixpoint decode_exploded {ls}
{x0} {x : member x0 ls} {y0} {y : member y0 ls}
: code ls (existT _ _ x) (existT _ _ y)
-> { p : x0 = y0 | rew [fun x' => member x' ls] p in x = y }.
Proof.
destruct x as [x xs H|x xs m];
[ clear decode_exploded | specialize (decode_exploded xs _ m) ];
do_member_small_inversion_on y;
unfold code, beq; simpl; repeat intro; subst;
repeat first [ reflexivity
| exists eq_refl; reflexivity
| repeat intro; exfalso; apply Bool.diff_false_true; assumption
| match goal with
| [ IH : forall y y', _ = true -> _, H' : _ = true |- _ ]
=> specialize (IH _ _ H'); destruct IH; subst
end ].
Defined.
Definition decode {ls} {x y : members ls} (H : code ls x y) : x = y.
Proof.
destruct (decode_exploded H), x, y; simpl in *; subst; reflexivity.
Defined.
Definition decode_false {ls} {x y : members ls} (H : beq x y = false)
: x <> y.
Proof.
unfold beq in *; intro H'; subst; rewrite encode'_exploded in H; congruence.
Qed.
Definition dec (P : Prop) := {P} + {~ P}.
Definition dec_eq_members (xs : list A) (m m' : members xs) : dec (m = m')
:= (if beq m m' as c return beq m m' = c -> _
then fun H => left (decode H)
else fun H => right (decode_false H))
eq_refl.
End with_type.
On Wed, May 17, 2017 at 8:46 AM Ben Sherman <sherman AT csail.mit.edu> wrote:
From: Klaus Ostermann <klaus.ostermann AT uni-tuebingen.de>Subject: Re: [Coq-Club] How to represent tabular data in CoqDate: May 10, 2017 at 4:19:57 AM EDT
Dear Ben,
thanks these are very useful pointers.
A few question, though: Why don't you use the "In" predicate from
the standard library instead of "member"?Note that [In] is a prop, whereas [member] is a type. Since [In] is a prop, it can't be used to retrieve any information, like looking up an element in a list. For example, imagine the list [1; 1]. If I have [p : In 1 [1; 1]], I don't know whether the proof was made with the first or second member of the list (in particular, it is admissible to assume that all elements of [In 1 [1; 1] are equal), but if I have [p : member 1 [1; 1]], that data may be used computationally.Haven't you only given me the interface for tables but not their
representation?
How would I construct an actual table?You would write a lambda that computes the value from the indices (i.e., [members] terms) that are input. So you'd be pattern matching on those [members] terms. Here's some example code that might give some idea:Fixpoint get_members {A} {xs : list A} (m : members xs) : A:= match m with| here' x _ => x| there' _ _ m' => get_members m'end.Fixpoint to_nat {A} {xs : list A} (m : members xs) : nat:= match m with| here' _ _ => 0| there' _ _ m' => S (to_nat m')end.Fixpoint eq_members {A B} {xs : list A} {ys : list B}(m : members xs) (m' : members ys) :=Nat.eqb (to_nat m) (to_nat m').Definition ComputeTable {R C A} (r : list R) (c : list C)(f : R -> C -> A) : Table' R C r c A :={| lookup' := fun mr mc => f (get_members mr) (get_members mc) |}.Definition UpdateTable {R C A r c}(t : Table' R C r c A) (mr : members r) (mc : members c)(a : A): Table' R C r c A:= {| lookup' := fun mr' mc' =>if andb (eq_members mr mr') (eq_members mc mc')then aelse lookup' _ _ _ _ _ t mr' mc' |}.The difference between "member" and "members" is also interesting.
How do I "see" that "member" requires UIP?Sorry, I wasn't clear about this. Neither one requires UIP. But I believe the types [members xs] and [sigT (fun x => member x xs)] are isomorphic only if [A] satisfies UIP. The reason is that [member] could be equivalently definedInductive member {A} (x : A) : list A -> Type :=| here : forall y xs, x = y -> member x (y :: xs)| there : forall y xs, member x xs -> member x (y :: xs).So if there is more than one proof of [x = y], there will be more elements in [sigT (fun x => member x xs)] than [members xs]. Usually I've found that I prefer [members] to [member] for this reason.
- [Coq-Club] How to represent tabular data in Coq, Klaus Ostermann, 05/08/2017
- Re: [Coq-Club] How to represent tabular data in Coq, Wilayat Khan, 05/09/2017
- <Possible follow-up(s)>
- Re: [Coq-Club] How to represent tabular data in Coq, Ben Sherman, 05/10/2017
- Re: [Coq-Club] How to represent tabular data in Coq, Klaus Ostermann, 05/10/2017
- Re: [Coq-Club] How to represent tabular data in Coq, Ben Sherman, 05/17/2017
- Re: [Coq-Club] How to represent tabular data in Coq, Jason Gross, 05/17/2017
