- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Stuck with an induction proof using subset types
- Date: Fri, 19 May 2017 10:18:00 +0200
- Organization: LORIA
Hi Klaus,
Well I do not really understand what got you stuck.
Here is a possible proof.
Best,
Dominique
Lemma lookup_correct : forall A (pairs : list (nat * A)) key s (m :
member s pairs),
lookup pairs key = Some (existT _ s m ) -> key = fst s.
Proof.
induction pairs as [ | (n,a) pairs IH ]; simpl; intros keys (i,b) m Hs.
discriminate Hs.
generalize (beq_nat_true keys n) (beq_nat_false keys n); intros H1 H2.
destruct (beq_nat keys n).
injection Hs; clear Hs; intros; subst i b.
rewrite H1; auto.
case_eq (lookup pairs keys).
intros (p & m') Hp; rewrite Hp in Hs; apply IH in Hp.
injection Hs; intros; subst; auto.
intros H; rewrite H in Hs; discriminate.
Qed.
Le 19/05/2017 à 09:47, Klaus Ostermann a écrit :
> Fixpoint lookup_simple {A} (pairs: list (nat * A)) (key :nat) : option
> (nat * A) := match pairs with
> | [] => None
> | a :: ss => if (beq_nat key (fst a))
> then Some a
> else match (lookup_simple ss key) with
> | None => None
> | Some b => Some b
> end
> end.
> It's a simple induction proof to prove that they returned pair has the
> correct key.
> Lemma lookup_simple_correct : forall A (pairs : list (nat * A)) key s ,
> lookup_simple pairs key = Some s -> key = fst s.
> However, my lookup function should also return a proof that the returned
> pair is
> in the original list. For this I use a subset type:
> Inductive member (A : Type) (x : A) : list A -> Type :=
> | here : forall l, member x (x :: l)
> | there : forall y l, member x l -> member x (y :: l).
> Fixpoint lookup {A} (pairs: list (nat * A)) (key :nat) : option { s:
> (nat * A) & member s pairs} := match pairs with
> | [] => None
> then Some (existT _ a (here a ss))
> else match (lookup ss key) with
> | None => None
> | Some (existT s m) => Some (existT _ s (there a m))
> end
> end.
> The new version of the correctness lemma is easy to state:
> member s pairs),
- [Coq-Club] Stuck with an induction proof using subset types, Klaus Ostermann, 05/19/2017
- Re: [Coq-Club] Stuck with an induction proof using subset types, Dominique Larchey-Wendling, 05/19/2017
- Re: [Coq-Club] Stuck with an induction proof using subset types, Klaus Ostermann, 05/19/2017
- Re: [Coq-Club] Stuck with an induction proof using subset types, François Thiré, 05/19/2017
