coq-club - Re: [Coq-Club] Stuck with an induction proof using subset types
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Stuck with an induction proof using subset types
  • Date: Fri, 19 May 2017 12:33:11 +0200
  • Organization: LORIA
The generalize is just a trick to keep track
of the properties on the Boolean value
(beq_nat_true keys n) after the next destruct.
As case_eq would to the same but after that
you need to apply beq_nat_[true,false] anyway.
Dominique
Le 19/05/2017 à 11:47, Klaus Ostermann a écrit :
> Hi Dominique,
> thanks for your solution. That's quite instructive.
> The puzzle piece I was missing is the "generalize (beq_nat_true keys n)"
> part.
> I'm still trying to understand why exactly it is necessary.
> Klaus
> Am 19/05/17 um 10:18 schrieb Dominique Larchey-Wendling:
>> Hi Klaus,
>> Well I do not really understand what got you stuck.
>> Here is a possible proof.
>> Best,
>> Dominique
>> Lemma lookup_correct : forall A (pairs : list (nat * A)) key s (m :
>> member s pairs),
>> lookup pairs key = Some (existT _ s m ) -> key = fst s.
>> Proof.
>> induction pairs as [ | (n,a) pairs IH ]; simpl; intros keys (i,b) m Hs.
>> discriminate Hs.
>> generalize (beq_nat_true keys n) (beq_nat_false keys n); intros H1 H2.
>> destruct (beq_nat keys n).
>> injection Hs; clear Hs; intros; subst i b.
>> rewrite H1; auto.
>> case_eq (lookup pairs keys).
>> intros (p & m') Hp; rewrite Hp in Hs; apply IH in Hp.
>> injection Hs; intros; subst; auto.
>> intros H; rewrite H in Hs; discriminate.
>> Qed.
>> Le 19/05/2017 à 09:47, Klaus Ostermann a écrit :
>>> Fixpoint lookup_simple {A} (pairs: list (nat * A)) (key :nat) : option
>>> (nat * A) := match pairs with
>>> | [] => None
>>> | a :: ss => if (beq_nat key (fst a))
>>> then Some a
>>> else match (lookup_simple ss key) with
>>> | None => None
>>> | Some b => Some b
>>> end
>>> end.
>>> It's a simple induction proof to prove that they returned pair has the
>>> correct key.
>>> Lemma lookup_simple_correct : forall A (pairs : list (nat * A)) key s ,
>>> lookup_simple pairs key = Some s -> key = fst s.
>>> However, my lookup function should also return a proof that the returned
>>> pair is
>>> in the original list. For this I use a subset type:
>>> Inductive member (A : Type) (x : A) : list A -> Type :=
>>> | here : forall l, member x (x :: l)
>>> | there : forall y l, member x l -> member x (y :: l).
>>> Fixpoint lookup {A} (pairs: list (nat * A)) (key :nat) : option { s:
>>> (nat * A) & member s pairs} := match pairs with
>>> | [] => None
>>> then Some (existT _ a (here a ss))
>>> else match (lookup ss key) with
>>> | None => None
>>> | Some (existT s m) => Some (existT _ s (there a m))
>>> end
>>> end.
>>> The new version of the correctness lemma is easy to state:
>>> member s pairs),
