coq-club - Re: [Coq-Club] Consistency of Coq ?
  • From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Consistency of Coq ?
  • Date: Fri, 7 Jul 2017 16:00:22 +0200
Hello.
I would like to mention also http://dl.acm.org/citation.cfm?id=1227232:
The open calculus of constructions (part I): an equational type theory with dependent types for programming, specification, and interactive theorem proving,
Mark-Oliver Stehr,
Fundamenta Informaticae 68(1-2):131-174, 2005.
Le 07/07/2017 à 15:25, Bas Spitters a écrit :
Lee-Werner seem to lack coinductive types, modules, but also have:
Prop:Type0
However, Coq has:
Prop:Type1
https://coq.inria.fr/refman/Reference-Manual006.html
Lee-Werner observe that:
In this paper, we do not consider the sort Set. Indeed, when (the
impredicative or predicative sort)
Set is placed at the lowest level in the hierarchy of sorts, as in the
case of the current development of Coq, there is no way to provide a
universal set-theoretic interpretation of both Set and Prop, as
identified by [Reynolds(1984)].
On Fri, Jul 7, 2017 at 9:07 AM, Bas Spitters
<b.a.w.spitters AT gmail.com>
wrote:
Thanks (I should have mentioned Bruno's work).
It would be good to record these works and their limitations.
I did not find an entry in cocorico, for instance.
On Fri, Jul 7, 2017 at 9:02 AM, Amin Timany
<amintimany AT gmail.com>
wrote:
Hi Bas,
It is indeed one of them. This paper establishes consistency by constructing
a set theoretic model and showing the interpretation of the type false is
indeed empty. Another one is Bruno Barras’ habilitation
http://www.lix.polytechnique.fr/~barras/habilitation/. He proves strong
normalization for CIC and all proofs are also formalized Coq itself on top
of an axiomatization of IZF (Intuitionistic ZF).
It should be noted though that these are not formalizing exactly what we in
Coq but they are pretty close. For example, if I’m not mistaken, neither of
them considers inductive types in Prop or eta expansion.
Regards,
Amin
On 7 Jul 2017, at 09:07, Bas Spitters
wrote:
https://coq.inria.fr/faq
"Proofs of consistency of *subsystems* of the theory of Coq can be
found in the literature."
Is this what is intended?
Proof-irrelevant model of CC with predicative induction and judgmental
equality
Lee-Werner
https://arxiv.org/abs/1111.0123
It might be good to add some references to the FAQ.
