coq-club - Re: [Coq-Club] Issues with Ocaml Toplevel in Coq [coq-club][coqdev]
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Issues with Ocaml Toplevel in Coq [coq-club][coqdev]
  • Date: Fri, 7 Jul 2017 16:57:37 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=psacawa AT math.toronto.edu; spf=Pass smtp.mailfrom=psacawa AT math.toronto.edu; spf=None smtp.helo=postmaster AT mail.math.toronto.edu
  • Importance: Normal
  • Ironport-phdr: 9a23:vpHN0h9MUKxBoP9uRHKM819IXTAuvvDOBiVQ1KB41+IcTK2v8tzYMVDF4r011RmSDNqds6oMotGVmpioYXYH75eFvSJKW713fDhBt/8rmRc9CtWOE0zxIa2iRSU7GMNfSA0tpCnjYgBaF8nkelLdvGC54yIMFRXjLwp1Ifn+FpLPg8it2e2//5/ebx9UiDahfLh/MAi4oQLNu8cMnIBsMLwxyhzHontJf+RZ22ZlLk+Nkhj/+8m94odt/zxftPw9+cFAV776f7kjQrxDEDsmKWE169b1uhTFUACC+2ETUmQSkhpPHgjF8BT3VYr/vyfmquZw3jSRMMvrRr42RDui9b9mRx3miCkJKjA38H/ZhcJ/g61HrxyvvR9wzpXIYIyWKPZyYr/Rc84BRWdHQ81fVzZBAoS5b4YXAeYPJ/xXr5T5p1ATsBWxHxWjC/nhyzBSiHP9wKo30/w6EQ7cwAMvBdwPv27PodXwLqgSTeC1wLPUzTXEdfNW3jH96JTPchw7v/6DQK9wfNPXxEIyFA3Flk2dpZH7Mz6WzOgBrnSX4/Z6We+uiGMrsQB8rzu3yssxiYTEiZgZxk3L+Ch92oo4K961RFRmbdK5EpZdsTyROZFsTcM4WW5ovT43yr0Ytp6/eygH0JEnyATea/yDaYSI5wjsVPqRITtimHJlf6i/hxG08Ui8ze3wTNe730tXriZdk9nMsG4C1wDL58SaVPdw/V2t1SuT2wzP8O1JIEM5mbDaJpMi2rIwk4AcsUXHHi/4gkX2i6qWe108+uiz8evofq/pp5GGOIJvjwHxKLgumsylDeQkNQgORW+b+eKg1L3k50H2XqhFjuAunqnDrJ/aPdgbprK+AwJNzokj7A+/Ay6639QcgHkIN0lIeAmHjojsI1HBOur0Dfa5g1S2kTdk3erKPrP7AsaFEn+Wm7D4OL159kR0yQwpzNkZ6YgHJKsGJae5YkbssJTjBxQwLAX+i7L/E9x235wXcWeGHq/fLKTItlmU4aQiL/TaN9xdgyr0N/Vwv62mtnQ+g1JIJaQ=
Thanks for the help. I had some issues with installation that caused
#use "include"
to not function correctly. I thought I was expected to run
#cd "checker";;
first. Thanks again.
> I don’t know much about the OCaml top-level, but it does work for me.
> I’m working directly from the Coq sources; I’m not sure about the
> binary
> releases. Here’s what I did:
> make world coqbyte pluginsbyte
> ./bin/coqtop.byte
> This brings up the Coq toplevel. Now run Drop. to get to an OCaml
> top-level.
> You first have to run #use "include";; (there’s also #use
> "base_include";;,
> documented in the text file dev/doc/debugging.txt, which does not load the
> pretty printers). The reference manual mentions this, but isn’t clear
> that
> this is actually required to use go(). We could probably also reference
> some documentation upon running Drop.
> This command prints a bunch of functions that are now defined. These
> include go (to exit) and a bunch of conveniences like parse_constr and
> parse_tac to easily construct terms, for example:
> # let nat = parse_constr "nat";;
> val nat : API.Constrexpr.constr_expr =
> {CAst.v = API.Constrexpr.CRef (API.Prelude.Ident (Some (0,3), nat),
> None);
> loc = Some (0,3)}
> # let repeat_subst = parse_tac "repeat subst";;
> val repeat_subst : Tacexpr.raw_tactic_expr =
> Tacexpr.TacRepeat
> (Tacexpr.TacAlias (Some (7,12), (Coq.Init.Notations.subst_4C69D532,
> Hope that helps!
> On Thu, Jul 6, 2017 at 11:36 PM, Paul Sacawa
> <psacawa AT math.toronto.edu>
> wrote:
>> Hello,
>> I'm an amateur in Ocaml and Coq trying to conduct some experiments to
>> extend the functionality of the former. To get a handle on the classes
>> used I've tried using Coq's "Drop" Vernac command (6.8.2 in reference
>> manual) to enter Ocaml shell, and experiment. Some issues:
>> 1. "go();;" does not work to go back from ocaml toplevel to coq. How to
>> make it work?
>> 2. I'm unable to access any coq objects through the shell, either
>> directly, or via #load_rec (*.cmo files and coqtop.byte disagree on
>> module
>> interfaces). How can I most directly interface with the basic coq kernel
>> modules, like Term?
>> 3. Is there any documentation I should read to understand how to get a
>> grip on this?
>> Regards,
>> Paweł
