coq-club - Re: [Coq-Club] Pretty conversion of Coq to HTML?
  • From: Gabriel Scherer <gabriel.scherer AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>, jrw12 AT cs.washington.edu
  • Subject: Re: [Coq-Club] Pretty conversion of Coq to HTML?
  • Date: Fri, 14 Jul 2017 10:12:13 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gabriel.scherer AT gmail.com; spf=Pass smtp.mailfrom=gabriel.scherer AT gmail.com; spf=None smtp.helo=postmaster AT mail-it0-f41.google.com
  • Ironport-phdr: 9a23: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
It is a shame that proviola is unmaintained, because I think such a
tool remains very useful for the Coq community. (It serves a different
purpose than jsCoq that is more interactive but heavier on the user).
James, what tool did you use for you indeed awesome dep-destruct
webpage? The fact that the same goals-on-hover rendering does not
exist for your other posts (
https://homes.cs.washington.edu/~jrw12/SharedMem.html for example )
unfortunately suggests that there may be a fair amount of manual
effort involved.
Should proviola be revived? Can implementing some features Coq-side
(having a tracing mode that would dump the location-indexed goal
information?) to make such tools more robust and easier to maintain?
On Fri, Jul 14, 2017 at 6:28 AM, Lélio Brun
<lelio.brun AT inria.fr>
wrote:
> Hello,
> the nicest pretty-printing I've seen so far was here:
> https://homes.cs.washington.edu/~jrw12/dep-destruct.html
> I don't think it uses proviola, which indeed seems to be unmaintained.
> Maybe you could ask directly the author of the post:
> Lélio Brun
> ----- Mail original -----
>> De: "Gaetan Gilbert"
>> <gaetan.gilbert AT ens-lyon.fr>
>> À:
>> Envoyé: Mercredi 12 Juillet 2017 15:07:07
>> Objet: Re: [Coq-Club] Pretty conversion of Coq to HTML?
>> If you mean this
>> http://hott.github.io/HoTT/proviola-html/HoTT.Spaces.Nat.html it's
>> proviola https://arxiv.org/abs/1005.2672
>> I think its site is dead though.
>> Gaëtan Gilbert
>> On 12/07/2017 15:02, François Pottier wrote:
>> > Hello,
>> > I believe I have seen somewhere (during an academic presentation,
>> > probably) a
>> > tool that converts Coq files to HTML files, with the feature that
>> > pointing the
>> > mouse cursor anywhere in the middle of a rendered proof script causes the
>> > current proof state (hypotheses and goal) to be displayed. I can't
>> > remember
>> > how it is called, and I can't find it, though. Any help would be welcome.
>> > Thanks,
>> > François Pottier
>> > francois.pottier AT inria.fr
>> > http://gallium.inria.fr/~fpottier/
