coq-club - Re: [Coq-Club] More than one ring structure (e.g. modulo ring) for one type
  • From: Gaetan Gilbert <gaetan.gilbert AT ens-lyon.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] More than one ring structure (e.g. modulo ring) for one type
  • Date: Mon, 17 Jul 2017 19:49:03 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT ens-lyon.fr; spf=Neutral smtp.mailfrom=gaetan.gilbert AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
  • Ironport-phdr: 9a23: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
OK I did my experiment wrong. If you do the following it works, but if
you replace the various T' by T it doesn't work, see comments.
(the original experiment I did had the [Add Ring rm2] after t1 so
didn't detect failure properly)
#+BEGIN_SRC coq
From Coq Require Import Reals.
Variables (T : Type).
Variables (z1 o1 : T).
Variables (a1 m1 : T -> T -> T).
Definition T' := T.
Variables (z2 o2 : T).
Variables (a2 m2 : T -> T -> T'). (* if returning T the call in t2 fails *)
Definition rm1 : semi_ring_theory z1 o1 a1 m1 eq.
Admitted.
Definition rm2 : @semi_ring_theory T' z2 o2 a2 m2 eq. (* explicit T' can be left implicit if z2 : T'. otherwise the call in t1 fails. *)
Admitted.
Add Ring rm1 : rm1.
Add Ring rm2 : rm2.
Lemma t1 : a1 z1 o1 = o1.
Proof. ring. Qed.
Lemma t2 : a2 z2 o2 = o2.
Proof. ring. Qed.
#+END_SRC
This is with a minimum of T' to get it to work so that we can see
where they're necessary, in practice you would want [z2 : T'] (or get
failures whenever it is on the left hand side of an equation) and
[a2 : T' -> T' -> T'] (for consistency).
So it looks like the type a ring is registered as is the implicit
argument to the semi_ring_theory (the type of the zero if left
implicit), and when it looks at a type [h e1 e2] (where h may itself
be an application) it gets the type T of e1 and if that's a known ring
checks if h is the registered identity.
Gaëtan Gilbert
On 17/07/2017 18:39, Soegtrop, Michael wrote:
Dear Gaetan,
If this doesn't match your expectation, I can prepare a sample.
Please do.
attached please find a Z modulo ring example which shows two unexpected
behaviors of the ring tactic:
1.) it looks like the ring operators applied to literal coefficients need to
compute with simpl, which is a serious restriction since simpl does not
behave in a very consistent way. It is not sufficient that operators applied
on literal coefficients compute with cbv.
2.) addition of ring structures for the same type hides previously defined
ring structures, even if all relations are different.
Best regards,
Michael
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Christian Lamprechter
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
