- To: Emilio Jesús Gallego Arias <e AT x80.org>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Building an ml plugin for Coq 8.5pl2
- Date: Mon, 11 Sep 2017 03:04:59 +0000
- Accept-language: en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=kendroe AT hotmail.com; spf=Pass smtp.mailfrom=kendroe AT hotmail.com; spf=Pass smtp.helo=postmaster AT NAM01-SN1-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23:N4b//hS93GoP6yMH4tTm14I/VNpsv+yvbD5Q0YIujvd0So/mwa64ZRKN2/xhgRfzUJnB7Loc0qyN7PCmBDRIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnZBUin4YCdwJ+D0Hbnwgt8lzNed8pnXbgpPsxOnYLppZEG7hRWB7o8Rm4Q0bu57wRzQ53BMZu5+xGVyJFvVkQy2rpO7+4cm+CBNsdog8dRBWOP0ZfJrY6ZfCWEFPmYz6dHr/SPEQEPb5XYaXn8RnzJIBBTA5RD+GJz2t32p5aJGxCCGMJiuHvgPUjO44vIzRQ==
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Actually, I figured out this error. It turns out the files in the .mllib file need to be ordered by dependencies.
- Ken
From: coq-club-request AT inria.fr <coq-club-request AT inria.fr> on behalf of Kenneth Roe <kendroe AT hotmail.com>
Sent: Sunday, September 10, 2017 7:34 PM
Cc: Coq-Club
Cc: Coq-Club
Thanks. I'm getting a bit further. I created an AdvancedRewritePlugin.mllib with the following contents:
Builtin
Cache
Rcontext
Crewrite
Derive
Disc
Env
Exp
ExpIntern
Getfile
Inner
Intern
Kbrewrite
Lex
Match
Mylist
Parser
PrettyPrint
Rule_app
Rsubst
Rtrace
Rtype
Rtrie
Advanced_rewrite
I added it to my _CoqProject. I still get the following error:
"coqc" -q -R "theories" AdvancedRewrite -I "src" theories/advancedRewrite.v
File "./theories/advancedRewrite.v", line 1, characters 0-42:
Error: while loading src/AdvancedRewritePlugin.cmxs:
no implementation available for Rtype
make[1]: *** [theories/advancedRewrite.vo] Error 1
make: *** [plugin] Error 2
This error appears when I compile the file "theories/AdvancedRewrite.v" which contains one file:
Declare ML Module "AdvancedRewritePlugin".
How do I fix this error?
- Ken
Sent: Sunday, September 10, 2017 4:50 PM
To: Kenneth Roe
Cc: Coq-Club
To: Kenneth Roe
Cc: Coq-Club
e AT x80.org (Emilio Jesús Gallego Arias) writes:
> Assuming you are using Coq 8.7 [which you should be], I suggest you add
> a file to _CoqProject:
> src/advanced_rewrite_plugin.mlpack
Oh, I missed the Coq version in the Subject. Then, you may want to use a
mllib file:
> src/advanced_rewrite_plugin.mllib
and list the modules your plugin will need.
E.
mllib file:
E.
- [Coq-Club] Building an ml plugin for Coq 8.5pl2, Kenneth Roe, 09/11/2017
- Re: [Coq-Club] Building an ml plugin for Coq 8.5pl2, Emilio Jesús Gallego Arias, 09/11/2017
- Re: [Coq-Club] Building an ml plugin for Coq 8.5pl2, Kenneth Roe, 09/11/2017
- Re: [Coq-Club] Building an ml plugin for Coq 8.5pl2, Théo Zimmermann, 09/11/2017
- Re: [Coq-Club] Building an ml plugin for Coq 8.5pl2, Beta Ziliani, 09/11/2017
