- To: coq-club AT inria.fr, Kenneth Roe <kendroe AT hotmail.com>
- Subject: Re: [Coq-Club] Building an ml plugin for Coq 8.5pl2
- Date: Mon, 11 Sep 2017 13:31:59 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=theo.zimmi AT gmail.com; spf=Pass smtp.mailfrom=theo.zimmi AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f169.google.com
- Ironport-phdr: 9a23:zjDHNBBxB/kWA1BzFyjJUyQJP3N1i/DPJgcQr6AfoPdwSP76ocbcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6lX71zMZGw3+OAxpPay1X9eK14Xkn9y1rpbUekBDgCe3SbJ0NhS/6wvL8oE1jI1kJ7oxgiHOrzMceOlQyXlvKHqTmAr578a0upVk9nIDlegm8pt8UST9SJY5SLlVFjEvNWZ9sNHruB6FXwqK43o0XWAfkx4OCA/AukKpFqztuzf347IukBKROtf7GPVtAWyv
Hi,
I'm betting that you are using Coq 8.5pl2 because this is the version distributed with Ubuntu 16.10. If you update to Ubuntu 17.04, you will benefit from Coq 8.6. But note that the best way to get the latest version of Coq is not to use your distribution's package manager. Instead, you can turn to OPAM (or Nix, which is a less well known alternative).
Le lun. 11 sept. 2017 à 11:05, Emilio Jesús Gallego Arias <e AT x80.org> a écrit :
Kenneth Roe <kendroe AT hotmail.com> writes:
> Actually, I figured out this error. It turns out the files in the
> .mllib file need to be ordered by dependencies.
Indeed.
> Env
Be extremely careful here! You are using a module name in your plugin
that clashes with a module defined by Coq `Env`. This is bad, and even
if it works in practice, could create all kind of undefined behaviors.
You have to choices to solve this problem:
- rename your env module such that its name becomes globally unique
[wrt Coq and all the plugins you may ever load]
- Move to 8.6 and use a .mlpack file, so your plugin's modules will be
"packed" and these kind of conflicts are avoided.
E.
- [Coq-Club] Building an ml plugin for Coq 8.5pl2, Kenneth Roe, 09/11/2017
- Re: [Coq-Club] Building an ml plugin for Coq 8.5pl2, Emilio Jesús Gallego Arias, 09/11/2017
- Re: [Coq-Club] Building an ml plugin for Coq 8.5pl2, Kenneth Roe, 09/11/2017
- Re: [Coq-Club] Building an ml plugin for Coq 8.5pl2, Théo Zimmermann, 09/11/2017
- Re: [Coq-Club] Building an ml plugin for Coq 8.5pl2, Beta Ziliani, 09/11/2017
