- To: Coq-Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Augmenting Modules
- Date: Sun, 17 Sep 2017 09:13:09 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=helmut.brandl AT gmx.net; spf=Pass smtp.mailfrom=helmut.brandl AT gmx.net; spf=None smtp.helo=postmaster AT mout.gmx.net
- Ironport-phdr: 9a23:DU+bYBxjT8hW8G/XCy+O+j09IxM/srCxBDY+r6Qd0uMfIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2NBXupSiZ6idXMRHiP0IhLePsX4XWks6f1uao+pSVbR8e1wCwebdjEBLjrQjVs9QKx4F4I6A9zjPGp2sOfelKlk1yIlfGvxv449qstLR5+iJcv7p198NEVLjmOa4iRLpUCBwpNnBz4sD340qQBTCT72cRBz1F2iFDBBLIuUn3
I want to define a module with some basic functionality and then define a functor to augment the functionality. I have the problem that all works fine if I put all definitions in one file and I get a universe violation error if I put them in different files.
E.g. I define an option module with the two monadic functions 'make' and 'bind'.
Module Option.
Inductive t0 (A:Type) :=
| None: t0 A
| Some: A -> t0 A.
Definition t := t0.
Arguments None {A}.
Arguments Some {A} _.
Definition make {A:Type} (a:A): t A :=
Some a.
Definition bind {A B:Type} (m:t A) (f:A->t B): t B :=
match m with
| None =>
None
| Some v =>
f v
end.
End Option.
The I define the functor which augments the functionality of the basic monad.
Module Type MONAD0.
Parameter t: Type -> Type.
Parameter make: forall A:Type, A -> t A.
Parameter bind: forall A B:Type, t A -> (A -> t B) -> t B.
End MONAD0.
Module Monad_of (M:MONAD0).
Import M.
Arguments bind {A} {B} _ _.
Arguments make {A} _.
Polymorphic Definition map {A B:Type} (f:A->B) (m:t A): t B :=
bind m (fun a => make (f a)).
Polymorphic Definition apply {A B:Type} (f: t (A->B)) (m: t A): t B :=
bind f (fun f0 => map f0 m).
End Monad_of.
With that I can define
Module Option1 := Monad_of(Option).
If I put the module type MONAD0 and the functor 'Monad_of' into a different file (let's say 'Monad.v') then the following fails with a universe violation
Require Monad.
Module Option2 := Monad.Monad_of(Option).
For me it should be exactly the same. Can anybody give a hint on what is wrong and on how to remedy the situation. I want to build a library where I can stack many monads arbitrarily on top of each other. If I cannot make the definitions in different files then the situation gets unmanageable.
Thanks for any hint.
Regards
Helmut
- [Coq-Club] Augmenting Modules, Helmut Brandl, 09/17/2017
- Re: [Coq-Club] Augmenting Modules, Matthieu Sozeau, 09/18/2017
- Re: [Coq-Club] Augmenting Modules, Helmut Brandl, 09/18/2017
