- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Augmenting Modules
- Date: Mon, 18 Sep 2017 10:18:01 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-ua0-f173.google.com
- Ironport-phdr: 9a23:PfVxsBLevG6KKS/x4tmcpTZWNBhigK39O0sv0rFitYgXL/rxwZ3uMQTl6Ol3ixeRBMOAtKIC1rKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBWB6kG1uDUVA1D0MRd/DuXzAI/bycqthM6o/JiGRgxUmDq8bK46FxKkoAzM/p0TiJd+I6MZzxLVvnJNPeNMyjU7dhqogx/g65Lor9ZY+CNKtqd5+g==
Hi Helmut,
I can't reproduce your problem with either Coq 8.5(pl2) or Coq 8.6. Could you please report this at http://coq.inria.fr/bugs indicating your version?
Best regards,
-- Matthieu
On Mon, Sep 18, 2017 at 11:00 AM Helmut Brandl <helmut.brandl AT gmx.net> wrote:
I want to define a module with some basic functionality and then define a functor to augment the functionality. I have the problem that all works fine if I put all definitions in one file and I get a universe violation error if I put them in different files.E.g. I define an option module with the two monadic functions 'make' and 'bind'.Module Option.Inductive t0 (A:Type) :=| None: t0 A| Some: A -> t0 A.Definition t := t0.Arguments None {A}.Arguments Some {A} _.Definition make {A:Type} (a:A): t A :=Some a.Definition bind {A B:Type} (m:t A) (f:A->t B): t B :=match m with| None =>None| Some v =>f vend.End Option.The I define the functor which augments the functionality of the basic monad.Module Type MONAD0.Parameter t: Type -> Type.Parameter make: forall A:Type, A -> t A.Parameter bind: forall A B:Type, t A -> (A -> t B) -> t B.End MONAD0.Module Monad_of (M:MONAD0).Import M.Arguments bind {A} {B} _ _.Arguments make {A} _.Polymorphic Definition map {A B:Type} (f:A->B) (m:t A): t B :=bind m (fun a => make (f a)).Polymorphic Definition apply {A B:Type} (f: t (A->B)) (m: t A): t B :=bind f (fun f0 => map f0 m).End Monad_of.With that I can defineModule Option1 := Monad_of(Option).If I put the module type MONAD0 and the functor 'Monad_of' into a different file (let's say 'Monad.v') then the following fails with a universe violationRequire Monad.Module Option2 := Monad.Monad_of(Option).For me it should be exactly the same. Can anybody give a hint on what is wrong and on how to remedy the situation. I want to build a library where I can stack many monads arbitrarily on top of each other. If I cannot make the definitions in different files then the situation gets unmanageable.Thanks for any hint.RegardsHelmut
- [Coq-Club] Augmenting Modules, Helmut Brandl, 09/17/2017
- Re: [Coq-Club] Augmenting Modules, Matthieu Sozeau, 09/18/2017
- Re: [Coq-Club] Augmenting Modules, Helmut Brandl, 09/18/2017
