- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Macro for Ltac
- Date: Mon, 30 Oct 2017 14:25:00 +0100
- Organization: LORIA
Dear Pierre,
Thx for the suggestion but there is a problem with
the untyped argument <uconstr> which cannot be represented
as a Coq typed term.
Is there no way or extension for Tactic to manipulate
text ?
Dominique
Le 30/10/2017 à 12:03, Pierre Courtieu a écrit :
> Hi,
> I guess you should define a tactic taking a list (coq lists) over some
> inductive type describing the steps. Then some Tactic notation could get
> you close to the syntax you want.
> Pierre
> Le lun. 30 oct. 2017 à 10:26, Dominique Larchey-Wendling
> <mailto:dominique.larchey-wendling AT loria.fr>>
> a écrit :
> Dear all,
> I am wondering if there is a way to define macros within the
> tactic language.
> For instance, consider that I have already defined
> tactic notations such as:
> wcbv step
> wcbv iter <integer>
> wcbv hyp
> wcbv trans <uconstr>
> Then I would like to be able to write
> wcbv step, hyp, hyp, trans (t @ a), iter 2.
> instead of
> wcbv step; do 2 wcbv hyp; wcbv trans (t @ a); wcbv iter 2.
> Can I do this using Ltac and Tactic Notation ?
> Because it seems neither can input <text> as an
> argument (like latex or metapost macros would do)
> Thanks very much in advance for any hint
> Dominique
- Re: [Coq-Club] fun <-> forall, (continued)
- Re: [Coq-Club] fun <-> forall, Ralf Jung, 10/26/2017
- Re: [Coq-Club] fun <-> forall, Robbert Krebbers, 10/26/2017
- Re: [Coq-Club] fun <-> forall, Burak Ekici, 10/26/2017
- Re: [Coq-Club] fun <-> forall, Clément Pit-Claudel, 10/26/2017
- Message not available
- Re: [Coq-Club] fun <-> forall, Samuel Gruetter, 10/28/2017
- [Coq-Club] Macro for Ltac, Dominique Larchey-Wendling, 10/30/2017
- Re: [Coq-Club] Macro for Ltac, Pierre Courtieu, 10/30/2017
- Re: [Coq-Club] Macro for Ltac, Dominique Larchey-Wendling, 10/30/2017
- Re: [Coq-Club] fun <-> forall, Clément Pit-Claudel, 10/30/2017
- Re: [Coq-Club] fun <-> forall, Jason Gross, 10/31/2017
- Re: [Coq-Club] fun <-> forall, Clément Pit-Claudel, 10/31/2017
- Re: [Coq-Club] fun <-> forall, Cyril Cohen, 10/31/2017
