coq-club - Re: [Coq-Club] Macro for Ltac
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Macro for Ltac
  • Date: Mon, 30 Oct 2017 11:03:48 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f51.google.com
  • Ironport-phdr: 9a23:FHqaNhV0tEZ8dPc8xLC+ctqT4xTV8LGtZVwlr6E/grcLSJyIuqrYZRKDt8tkgFKBZ4jH8fUM07OQ6P+wHzFYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aSV3DMl9+If2wEYrPhey20fqz8tvdeVZmnj24NItzIQ+soE36sdQMnYpvN+5l0hrEuGFFPe9R2Hl0JF+Otxn578a0upVk9nID6Loa68dcXPCiLOwDRrtCAWF+Pg==
Hi,
I guess you should define a tactic taking a list (coq lists) over some inductive type describing the steps. Then some Tactic notation could get you close to the syntax you want.
Pierre
Le lun. 30 oct. 2017 à 10:26, Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr> a écrit :
Dear all,
I am wondering if there is a way to define macros within the
tactic language.
For instance, consider that I have already defined
tactic notations such as:
wcbv step
wcbv iter <integer>
wcbv hyp
wcbv trans <uconstr>
Then I would like to be able to write
wcbv step, hyp, hyp, trans (t @ a), iter 2.
instead of
wcbv step; do 2 wcbv hyp; wcbv trans (t @ a); wcbv iter 2.
Can I do this using Ltac and Tactic Notation ?
Because it seems neither can input <text> as an
argument (like latex or metapost macros would do)
Thanks very much in advance for any hint
Dominique
