- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Command line flags for warnings
- Date: Sun, 05 Nov 2017 11:16:04 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=theo.zimmi AT gmail.com; spf=Pass smtp.mailfrom=theo.zimmi AT gmail.com; spf=None smtp.helo=postmaster AT mail-vk0-f41.google.com
- Ironport-phdr: 9a23:5K19oBQoMSJJ+sn5O4uMgvwMRdpsv+yvbD5Q0YIujvd0So/mwa67YR2N2/xhgRfzUJnB7Loc0qyN7PCmBDRIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnZBUin4YAFyP6H+HpPYp8WxzeG7vZPJMCtSgz/oXbPzKyKErADUu9MTiI1kYvItyhbO5GlJfuFX7WxtLFOX2R3745Hjr9ZY7y1Mtqd5pIZ7WqLgcvFgQA==
Hi,
Section 6.9.3 (https://coq.inria.fr/distrib/current/refman/vernacular.html#SetWarnings) also says "Adding - in front of a warning or category disables it,
adding + makes it an error. It is possible to use the special
categories all and default, the latter containing the warnings
enabled by default."
"A is declared as a local axiom [local-declaration,scope]"
Le sam. 4 nov. 2017 à 23:27, Erkki Luuk <erkkil AT gmail.com> a écrit :
HiWhere do I find the command line flags for warning names and categories? The manual just says:-w (all|none|w1,…,wn)Configure the display of warnings. This option expects all, none or a comma-separated list of warning names or categories (see Section 6.9.3).Erkki
- [Coq-Club] Command line flags for warnings, Erkki Luuk, 11/04/2017
- Re: [Coq-Club] Command line flags for warnings, Théo Zimmermann, 11/05/2017
- Re: [Coq-Club] Command line flags for warnings, Erkki Luuk, 11/07/2017
- Re: [Coq-Club] Command line flags for warnings, Christian Doczkal, 11/08/2017
- Re: [Coq-Club] Command line flags for warnings, Théo Zimmermann, 11/09/2017
